Question about Dell Inspiron 6400 Notebook
Passwork Assignement Hell Eqbal, Wish you all the best , Eqbal I have an external hardisk and have a 4 partitions I want to assign for all of them a password , is that possible or ....?? Thanks and Regards Daoud
  • 5 more comments
  • daoud Apr 13, 2008
    Hello Friend,
    Thanks for the solution , one thing happend here when I give the value of 16 in the "value data" it hides both drives C:/ and E:/ any way onething else now both Drive has been vanish is there any way ? to find this drive and get data or some files automatically only should be avaliable for me , without to follow again the first step, how to do this ??
    Thanks and Regads
    Daoud
    Dear Eqbal,
    Thanks I did this direction it is working , but one thing when I plug the external hardisk to the other computer it is opening but I want in any computer it shouldn't opening ,
    Thanks and Regards
    Daoud
  • daoud Apr 14, 2008
    Thanks Eqbal,
    Dear Friend,
    My PC bluetooth is not working I installed some bluetooth software but it is not working , would you please give me some instruction,
    Thanks and Regards
    Daoud
  • daoud Apr 20, 2008
    Hello Eqbal ,
    Do you know about the linux ? I have forgot the user and Password of my linux system
  • daoud Apr 22, 2008
    Dear All ,
    Any body can help , I can not ping and have access to my Linux system from other PC , I tried and I checked the connectivity but not pinging , any small answer would be high appreciable
    Thanks and Regards
    Daoud
  • daoud May 20, 2008
    Dear All,
    Any one can solve the problem of the internet connectoin , it is connected to server and have receive and send and can get data from server but it can't browes the page of internet.hope to reply me ,
    Thanks
    Daoud
    President:
  • 1,257 Answers
Just any 3rd party software to make password protected to your partition .everytime you go in registry and change settings take time .just use 3rd party software it will be easy for you.....
Here is the link to download a software which will solve all your problems
http://www.filewatcher.com/m/TweakUiPowertoySetup.exe.150192.0.0.html
download this TweakUiPowertoy software its only 150 kb in size and very powerfull ...............................................enjoy
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Posted on Apr 28, 2008
  • 655 Answers
Hi daoud,
Fine how are you?
There are number of ways to protect/hide your HDD/Partion/Folders. Here I am giving an example 'How to Hide Your Drive i.e. Partition'. Follow these following simple and easy to use steps:
  1. Go to Start -> Run -> "regedit"
  2. Find: HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer
  3. Choose Edit -> New -> DWORD Value and give name NoDrives.
  4. Double click NoDrives and determine which drive that you want to vanish in Value Data.
    Ex: If you wish to vanish drive E:, insert value 16 in Value Data.
    The combination value in "Value Data" are as following:
    A: > 1
    B: > 2
    C: > 4
    D: > 8
    E: > 16
    F: > 32
    G: > 64
    H: > 128
    I: > 256
    J: > 512
    K: > 1024
and so on.........
There are also awailable software on the web for protecting your HDD. To have a look click here.
But be aware using HDD protection softwares, if you missed your password there is no chance to get your data back or to use any how your HDD.
Thanks
Iqbal
Posted on Apr 12, 2008
  • 4 more comments
  • Iqbal Husain
    Iqbal Husain Apr 12, 2008
    Sorry friend the complete Reg Key is here
    Thanks
    Iqbal
  • Iqbal Husain
    oopssssssss
    Policies/Explorer
    Use the above reg. key
    Thanks
    Iqbal
  • Iqbal Husain
    Iqbal Husain Apr 13, 2008
    Hi Daoud,
    Great you did the trick very well, but you have done a minor mistake thats why your both drives C: and E: vanished. Actually the values for drives listed above are in Decimal Base and you have entered the Value in Hexademal Base, i.e. if you want to put in hexadecimal then 16 will became 10.
    Nice, now your drive is not protected it just disappeared from My Computer to access the data on the drive Open My Computer and just type the drive letter in Address box followed by : in your case E: and then press enter key the content of the drive will be displayed.
    Thanks
    Iqbal
  • Iqbal Husain
    wow Daoud thanks, but m unhappy with your ratings, first you have given Fixya, Then Helpfull.......lol now m sure you will rate as thanks for Trying or Inappropriate.
    Anyways I was told you in my first solution thats there is a number of ways to do that. And the tric which i have given you is a registry modification means this value have not been written to specific disk its just written on system partition which contains the registry file, so it will be avial at another PC on which the registry key is not modified.
    To protect HDD there are thirdparties softwares which used to write your password on HDD and so it will be protected at any system. But the dengerious thing about using these software is that if you forget your password then your hdd will be un-useable. Even then you want to try, I have given a link for such type of sofware, you can use it on your own-risk.
    Thanks
    Iqbal
  • Iqbal Husain
    Iqbal Husain Apr 15, 2008
    Hi, Friend
    You should ask new question in new thread.
    Anyways, there is a number of reasoins that might cause Bluetooth problems.
    1. First check-out in device manager that the driver is installed currectly, there might not be any 'Yellow Marked' compnent, if you have any one marked with yellow color, means there is missing driver. If so, fix it by re-installing the proper driver.
    2. Then find out the bluetooth device is on and its in the range. If still did not fix, then try step 3.
    3. If driver is ok, then try this link, Microsoft Guides here how to troubleshoot Bluetooth Step by Step.
    Thanks
    Iqbal
  • Iqbal Husain
    Iqbal Husain Apr 22, 2008
    Dear friend,
    If you will ask question here, then this will come only to me. No other expert can see your question.
    I requested you before please ask your question in new thread. And I am sorry to inform you that I am not going to answer you any more because for my each answer I got degrade my rating from you. I think I am niether able to under stand your question nor you as after my solution which I think is correct, you gave me a down-grade rating.
    Anyways I again request you to ask your question in new thread.
    Thanks for using Fixya
    Iqbal
How to put my name on the front screen on a JVC KD-G430
I suggest check your User Guide in the section about Tittle Assignement.
Hope helps.
Oct 06, 2011 | JVC KD-G430 CD Player
My laptop Model Compaq 5204NR I want to extend my hardisk. Is it possible to use External Hardisk for this model laptop. If it means how much can i use 1TB hardisk or which is suitable for this laptop....
Yes you can use an external HDD to extend your current HDD. If by extend you mean use the external HDD for storage and such.
However if you wanted to literally extend your current HDD by creating a single partition for both HDDs then it could be extremely problematic because the external HDD will be connected with an USB cable. If you were to accidentally unplug the usb cable then your whole system would crash.
Feb 28, 2011 | HP Compaq Presario V5204nr Notebook
How to format excelstor hardisk?
For your specific operating system, assuming that Windows is running, locate Admistrative Tools -> Disk management.
You should see Disk 0 or Disk 1 with your Excelstor 80GB drive: if you do not have a partition, create one or more partition, assign drive letter(s) and then format using the context menu.
If you do not see the drive in the Disk Management screen, then your Bios has not been setup properly or your drive is not connected properly.
Hope it helps.
Sep 27, 2010 | Excelstor Technology J880 Hard Drive
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
MY external hard disk maxtor is not detected
Is this a new Maxtor external drive? It came with a CD. Run the utility.
If there is no data on it that you want to save, you can also blow away the partition and format it:
Right-click [My Computer]
[Manage]
[Disk Management]
Find your external Maxtor Disk inthe list and / or graph
Right-click on the disk and select either "Format" or "Delete Partition"
(try format first) Use "NTFS quick format"
If you delete the partition, then "Create Partition" and then format.
You can assign a drive letter or accept whatever it assignes (probably Drive D)
*done*
Sep 30, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Hardisk cleaned why?
this may be a hdd physical failure, best to check this would be to connect disk to another computer for a minute and run full HDTACH tests, if it's not damaged, then boot record is damaged, and Partition magic or similar program is needed to delete partition and re-create it
Sep 19, 2009 | Western Digital 250GB MyBook External USB...
Board not detect the hard disc
Check on the jumper setting of the ide and power cable
check if the ide cable is connected properly on ur mother board/try reverse if u are not sure it doesnt ur hardware.
Start on power button the then click on on delete continuesly until the cmos setup will appear then check ur hardisk and ur boot secquence.
sometime not delete are using using in opening cmos sometime f2 or whatever assign.
Use fdisk/to check ur partition/after that reformat in these case u can easily conclude if ur hardisk is bad or not
Jun 10, 2009 | ASUS M2N-MX Motherboard
My laptop is aspire 4315...b4 my partition in laptop is 2 w/c is drive c and d.now i change my internal hardisk,my partition is only one..my question is how to make a 2 partition just like mine b4?dri
New/ Fresh harddisk only has 1 partition. If you wish to make another partition from installed hdd, you may need partition manager software to do the task. Lots of partition manager on the web. Just google a free one. Try also Easeus partition manager. is a free software for partitioning. Resizing an hdd is simply using partition managers. You can do drive letter changing, format and volume naming.
You can also do resizing during installation of your OS.
Refer to your nearest technician for tech support.
Apr 25, 2009 | Computers & Internet
Uninstallation of Windows Vista ultimate Edition
Just boot from the installation cd. when prompted to repair or don't repair choose don't repair on the next step you'll asked to format the hardisk or leave the current partition. if you dont have any important data I recommend to format your hardisk. Backup yaour data before installing
Mar 21, 2009 | Microsoft Windows Vista Ultimate Edition
REMOVE WRITE PROTECTION FROM EXTERNAL DRIVE
insert your memory stick or your external drive / go to My Computer / right click your drive / go to properties / under the Security tab, just check the Full Control under permission / click apply then ok
hope this helps
Nov 04, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Dell Inspiron 6400 Notebook Logo
71 people viewed this question
Alun Cox
