Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Numark CD mix 2
Hi
My CD mix 2 appears to have loose connections at the main input and both of the phono inputs. When playing live it crackles badly. The leads are ok as they work fine with my spare Mix 2. Can I replace the back panel which supplies all the power?
Many thanks
  • 3rdjohn Apr 18, 2008
    I have had the CD-2 for a few years now , never really used it much, but latley I have been getting this real bad cracking noise while I'm at the club and it's become very unpredictable.
  • 1,512 Answers
Hi aondj
I would remove the back panel, and get access to the soldering of the connectors that are giving you trouble. resolder them, and see how you go. Get back to me here if this does not cure it and we shall get into it further
regards
Graeme
Posted on Apr 12, 2008
Connecting numark m3 to turntables
The m3 has two phono inputs in the back. There's a switch for either line- in or phone. Put the switch to phono.
Mar 20, 2013 | Numark M3 2-Channel Tabletop DJ Mixer
Can i connect my laptop to my numark cd 2
Yes, you just need the appropriate cables. The simplest being a 3.5mm jack to phono to make a direct link tween your laptop output and one of the two channel inputs. Then you simply choose phones on your front end (whichever channel you plugged into) and away you go.
Dec 16, 2012 | Nu Mark Numark Cd-Mix-2 Dual CD...
I have a Numark TT 1610 and it has the old school red and black audio out put wires, and just playing some of my old records is what i wanted, but its sound comes through my speakers so soft i have to...
It looks like your amplifier has not got a "magnetic cartridge pre-amp" built in, or you have it connected to a tape/cd input instead of a phono input. All you need is to search online for one and that will connect between your deck and amp and it will then be the same volume as anything else connected to the amp.
Jun 17, 2011 | Numark TT1610 Turntable
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
Hi there! i just bought a numark tt1650 and an ortofon arkiv cartridge, connected it properly to my old technics a700mk2 amplifier (phono, grounding and all that) but it still has a buzzing problem...
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
May 05, 2010 | Numark TT1650 Turntable
Crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Jun 25, 2009 | Denon AVR-2106 Receiver
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
Moodey newmark cd mix 2
Just wanted to tell you i have the same problem with my right deck! after about 2-3 hours of usage the right deck will start to skip while playing a cd...almost sounds like im fast forwarding then itll just stop playing, but only on the right deck! Ive noticed that it happens when the unit gets hot whether by usage or sunlight. Now as for youre issue about the crackling, i have two staements one is the cd youre playing scratched? ive had cds that have had minor path scratches that follow around the cd not straight across scratches..while playing this sounds like static or crackle then fades away! I would recommend playing the cd in a entirely different unit to see if this is the prob...if you know this is not the issue i would say that its a loose connection to a capicator or that a capacitor is on the way out...this happens when the capacitor is cold and doesnt let proper flow to go thru but as the capacitor heats up it it may heat the connection making a better contact.....just out of curiousity do you have the right rated fuse in the holder.. sometimes just having a fuse off by a couple of volts or milliamps can cause the same effect
Nov 12, 2007 | Nu Mark Numark CD-Mix-2 Dual CD...
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
150 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
