Question about Samsung ML 1210 Laser Printer
Randomly printer stops printing - need switch off and on to restart printing
Printer randomly stops printing after one or more printing. The printer message shows "error printing" and I can restart only switching off and on the printer.
Windows XP Pro
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Posted on Nov 13, 2008
  • lbecque Nov 13, 2008
    Here is the text from the other post:
    I have had the same problem with paper not picking up for some time and
    just discovered a much easier solution than taking the printer apart to
    replace the roller!!
    In the past I had cleaned the pickup
    roller with alcohol but found that to only work for a few days. The
    roller has two high spots on it so you have to turn the printer off
    several times while it is rotating to various positions to make sure
    you clean both of the high spots which pick up the paper.
    The
    permanent solution is to lightly coat these worn sections of the roller
    with rubber cement (aka paper cement, it dries rubbery and sticky and
    usually comes with a brush in the cap of the jar). Rubber cement is old
    fashioned stuff you used to find in office stores but not so much
    anymore, I had to go to a craft store to find some. I tried the newer
    paper glues that come in a stick but these dry to a slippery surface
    and don't work, you need the old fashioned rubbery stuff.
    Problem solved. Much easier than taking the whole printer apart too.
Randomly prints when closed
Uninstall it completely, removiing drivers. Chech at HP website if more recent driver is available for your model and Operating system and reinstall it.
Oct 26, 2015 | HP DeskJet Office Equipment & Supplies
Ink on the 1012 printer is intermittent
Are the gaps, always in same place ,or randomly ?
IF same place maybe , laser door r laser shatter , hang or stick in place , if the Gaps randomly , means toner cartridge is faulty need to be change . I hope was helping you
Mar 23, 2013 | HP LaserJet 1012 Printer
Printer keeps printing out a Google page!!
This must be a memory issue unplug the usb cable and plug from outlit, and restart computer, wait about 5 minutes then plug the cables back in.
Jul 13, 2010 | Brother MFC 490cw Color Inkjet...
My printer drops and reconnects its USB connection
Mine had a faulty on-off switch that cycled on & off due to vibrations. A carboard shim at the switch stopped the problem.
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
Pitch changes midway through job and randomly reprints over lines
Check the cable. It looks like some sort of interference over the cable. Make sure it does not lie next to power cable.
Jul 17, 2009 | Matrix Okidata 120V Printer
''clicking'' noise started randomly- cant use printer
Hi starrz54,
Here is the HP site that talks about resolving unexpected noises (such as clicking)...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06191&lc=en&dlc=en&cc=us&lang=en&rule=26695&product=303753
You also might try doing a full reset on the device. Here is how to do that: While switching on the scanner press # and 9 to initialize.
I
This should give you some good directions and if it does not resolve the issue, the next step would be to have it serviced or replaced.
Nov 16, 2008 | HP PSC 2410 All-In-One InkJet Printer
Printers randomly stop working
Hi Will,
This machine doesn't have on and off switch. After changing label roll you need to unplug power for a few secs and plug it back in. This will stop windows from showing the "print error" message.
Oct 09, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Failure of an Epson Stylus R 1800 printer to print properly conistently.
Here is the solution:
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
Samsung ML 1210 Laser Printer Logo
124 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
