Question about Nokia 5300 Grey Cellular Phone
Freezing I was outside today using the phone, when i decided to check out a game, one the game started I realized the volume was low, i tired to turn it up but it took 3 or so seconds to respond and i saw that i accidentally put it up too high so i tried to put it down again, then all of a sudden it freezes and all i can see is the volume bar and it wont dissapear. Oh and when i try to turn it on it makes the vibration notifying me its on but the screen doesn't change one bit, the volume bar is still there and whenever i press the "up" volume or "down" volume it won't change please help me!
  • 24 Answers
Try taking the back cover off then cleaning them out (buttons) they may be stuck try it and write back :)
Posted on Apr 12, 2008
Dca213d window unit keeps freezing is it thermostat?
Check for badly bent fins or obstructed/dirt impacted fins on the outside of the unit. Could also be low on gas. Try setting the t/stat to various settings see if its turning off/on at higher settings, if it does most likelt stat is OK. Also make sure you drian is clear.
Aug 12, 2014 | Carrier Heating & Cooling
When I turn on my Kyocera phone it freezes when it's turning on
Are you able to use it all? Is it turning on? *by the way, I just replaced my Hydro today..Anyway, You need to delete emails, texts and apps, clear up some space. I had to do that several times. Today I got tired of it and bought another kind of phone.
Mar 05, 2014 | Boost Mobile Kyocera Hydro Smartphone
I've been having problems with my phone for a while now. It's been freezing up, cutting off by itself, & other random stuff. Today, I sent a text & the phone shut off! I did the usual 'take th
Try to check if your phone memory still have enough space. common cause for freezing and shutting off is when your phone memory is almost full. try deleting some stuff.
May 25, 2017 | Samsung M8800 Pixon - Unlocked QuadBand...
Panasonic Kx-tea 308 low volume problem, using kx-t7730 and kx-t7720 handsets, low volume on all handsets, both sides of conversation. Panasonic sent new pc and handsets shortly after system was...
If you have to eat the system, I'd suggest butter, salt and pepper LOL
Seriously, what happens when you plug a regular phone directly into the outside lines? Or, better yet, plug a regular phone into jack 01 and TURN OFF THE POWER on the phone sytsem.
Now you have a phone wired to the outside line. If you can hear on those, then you may have a line current issue, or something else. If you can't, the telco is obligated to give you a line you can hear on. If they can't deliver, try an alternative like Vonage.
Carl
Sep 30, 2010 | Panasonic KX-T7730 Corded Phone
Wii freezing
it could be over heating so trying putting it in a different area
Aug 02, 2009 | Nintendo Wii Console
Central heat and air freezing up
It is not freezing because it's cold outside,It is freezing due to a problem.
It needs to thawed before it will work,
1st:Check or change the filter if need be.
2nd:Make sure none of the vents are blocked off(especially the return)
3rd:The only way to thaw it when temps are low outside,without being out in the weather is to turn on the air conditioner,You will need to use other means to heat your home until it thaws.
and Please if you use the stove for heating,don't fall asleep with it on.
Jan 17, 2009 | Heating & Cooling
360 keeps freezing
I had this problem also. I tried turning off and turning it back on but that didnt work. I learned that it is a software failure and unless you're a CPU programmer with high quality programs designed to write software then you cant fix it. Your best bet is to call customer support.
Jun 02, 2008 | Microsoft Xbox 360 Console
BUTTON ON THE OUTSIDE TO TURN THE VOLUME DOWN
try a full facroty master reset, if still persists,
take it to someone who knows how to 'flash' it
Mar 12, 2008 | Motorola Mobility RAZR V3
Nokia 5300 Grey Cellular Phone Logo
62 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
