Question about Technics SC-DV290 System
System stops playing
I have a technics sc-dv290. After 2 to 3 hours of continuous play, the system stops playing for no reason. I could be using any mode. When the system is turned off, then restarted, it will work for a couple of minutes, then cut off again. This has spoiled a few parties, as all our friends go home!!
Please help.
  • Big Belchie Apr 22, 2008
    Thanks for the speedy reply! However, the system is not in a cabinet, it sits on a table.
    Coincidently the fault happened again at the weekend. After about 2 hours of continuous play, the system refused to work. I checked the back, and sure enough the stereo tuner/ amplifier seemed to be overheating. Does anyone have a solution, or is it back to the supplier?
  • 1,512 Answers
Hi Big Belchie
Sounds a bit like it is overheating. It is in a cabinet? Check that cooling vents on top and sides of the unit are not getting obstructed. hehehe sometimes parties are responsible for those piles of cd covers that block off the vents. How hot does it feel when it stops working?
regards
Graeme
Posted on Apr 13, 2008
  • Graeme Ross
    Graeme Ross Apr 23, 2008
    hhmmmm so you agree with me that is is overheating, and confirmed that by actually checking the receiver section. I am a little bewildered as to why my solution prompted you to give me a "thanks for trying" rating generally reserved for solutions that are wrong or "not right" . My overall expert rating goes down with that sort of rating. Hoping you may reconsider that for me, I would appreciate it greatly.
    Over heating can be caused by a number of things. I take it(assuming as you did not mention it) that all the vents are clear of obstruction. changing the position of the components in the stack may help. Get the amp section to the top, where it can get the most air around it. If it has an fan to force air through the amp section, check that it is not clagged up with dust, or that the vent to it is also clear(use a paint brush to dust it out). Be sure to leave about 10cm behind the unit also to allow for cool air to convect by.
    If it still shuts down AND it is still under warranty, then YES return it to the supplier for replacement. It may have intermittent solder joints causing the problems.
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
No play
you most definately have a faulty spindle motor. this is very common on technics and panasonic dvd players. i've come across this fault on numerous occasions and after replacing the motor, all worked as it should. hope this helps?
Jan 25, 2009 | Technics SC-DV290 System
Technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
Nov 01, 2008 | Technics SC-DV290 System
Re: sl-dv290
it looks like you have to change laser some of the them lasts for a 1000 hours ....take to repair shop only for cleaning in that way you get the end of the laser life...........................saludos
Oct 19, 2008 | Technics SC-DV290 System
Technics sc-dv250
did you buy your system in adifferent region and moved with it to another? I heared something like some DVD players are region-locked. I could be wrong but google about region-lock... try this among others: http://dvd-player-software-review.toptenreviews.com/what-is-dvd-region-lock.html
Pikles
Mar 16, 2008 | Technics SC-DV290 System
Region 1 DVD's
i would like to buy this sterio TECHNICS SCEH790 HOME CINEMA MINI SYSTEM how can i buy it?Here is my email addressand <photonictech3@yahoo.com> so please sand to me phone nomber .please write back to me. boy from now
Dec 22, 2007 | Technics SC-DV290 System
TECHNICS SC-EH750-CD KEEPS SKIPPING
replace travers assy ,because spindle motor is faulty. If you can get spindle only it will be chiper solution for you.
Nov 10, 2007 | Technics SC-EH780 CD Shelf System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Won't play cds or dvds
you need a new motor in yr dvd player i had same problem had new motor works now
Aug 04, 2007 | Technics SC-DV290 System
Technics SC-DV290 System Logo
124 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
