Question about Kitchen Ranges
Right oven 2 burner natural gas.burners stay on for 20 seconds.
Right oven 2 burner left side stays on for 20 seconds then cycles on again.the right side will sometimes come on. the hot surface igniter is in series with gas valve.when on the voltage at the gas valve is 2.6 volts and stays at 2.6 volts when it cycles off.replaced the gas valve,same problem.left side oven 1 burner woks fine,compared gas valve voltage 2.6 volts.could there be a crack on the hot surface igniter? thanks.
  • 1 more comment
  • otispug Apr 14, 2008
    cleaned burners as instructed,also cleaned orifice's. also when i tap the gas valve both burners will come on but only for a few seconds. thanks.
  • otispug Apr 23, 2008
    checked gas pressure,ok. blew out gas line from the gas manifold,ok.there is no overload or limit switch in line with the gas valve,only the thermostat (also new) and the hot surface igniter. both igniters look like they are ok.the igniters are the only parts that have not been replaced.
  • Anonymous Mar 22, 2014
    Oven too hot. Thermostat does not turn off the burner
    Scholar:
  • 170 Answers
Ok you say you have your 2.6 durring the time your burner restarts.
how long is the flame out before it comes back on? if it is too quick then your multi meter may not catch the quick off and on.
if you have good flame then i would say its not a clog but if there is a sensor next to the flame then it maybe dirty and not telling the valve that its got flame, so in return the valve is turning it off, and restarting it again. some say to wipe sensor with a dollar bill if you use anything else it may damage it. if you don't have a sensor and you start seein a slight change in the 2.6 then your lookin at something differant.
Posted on Apr 14, 2008
  • Scott Henderson
    Scott Henderson Apr 14, 2008
    ok with everything being replaced. i would check your input gas and double check your voltage, but if you tap on the valve and it come on then it may have something clogging the input to the valve. I would start by checking how far back the problems start on the gas line. maybe check your shut offs around the back and around the house. if you have a lower tap or the lowest line in the house avl to you so you can shut off the gas and empty out water from the lines and check them.. please be carefull.
    Genius:
  • 1,447 Answers
Chances are there are Little specks of something either obstructing the orifices or there are little cracks or holes, what i can suggest is for you to connect the tubes on an air compressor, if by any you have one. then try to submerge the burnes to a pail of water if you can disassemble it for you to trace whether there is a leak/cracks. if none then something is obsructing gas to go through, try to get rid of the obstruction by increasing air pressure, using air compressor ok? hope this help.
  • 4,889 Answers
Looks like something is blocking the burners from the insides.. My mom has fixed a similar problem of my neighbor yesterday...the solution is to disassemble the burners and clean it thoroughly and put them back on..
Good Luck!
Eagle.
Posted on Apr 12, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Replaced igniter. Is it suppose to stay on the whole time the gas oven is on?
I assume you are talking about a glow bar type igniter. Yes they stay on as long as the burner is on but will cycle off when the oven reached the set temperature then come on to light the burner again when the oven cools back down to maintain the temperature.
May 10, 2015 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
I have a whirlpool GW395 gas stove with a problem. When you first turn it on it lights, it will stay lit for about 45 seconds then the burner will go off , after you let it set for about 45 seconds it...
The usual problem with these ovens is the oven burner itself. the burner will click 3 times and usually lights but after a few minutes shuts down and will no light again until you reset the control. If this is happening then try replacing the oven burner. It comes as one unit the burner assembly and electrode. Part # 8191123. If this doesn't work then it coould be your spark module unit. This is about twice the cost or more.
Dec 01, 2012 | Whirlpool GW395 Gas Kitchen Range
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
I have a Maytag 30 gas oven. When you set the temp., the oven fires up but the gas will turn on then off. Repeating this cycle over and over. It looks as though the gas supply is having a pressure or...
If it were the regulator you would have the same problem with the top burners. Is the oven burner coming on a little or to normal size? How long does the burner stay on each time?
Jan 16, 2010 | Maytag 30" Self-Cleaning Freestanding Gas...
36 inch range gas not flowing to both burners
I am having the same problem with my oven. One burner comes lights on just one side. Then the second one comes on. Just one side. After a while both side get lit. My concern is unburnt fuel coming out of the oven. Going to trying taking the burner out and cleaning the ports
Sep 18, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
