Question about Labtec C-322 Headset
Headset how do the headsets work? I have a Labtec LVA7330 i pluged it in and my voice comes over the speakers. But what are they used for and how do I use it?
  • 156 Answers
You use headsets to have conversations over the internet .. or to have a personalised audio equipment,.
You should have used the mic to start with, as you heard over the speaker your voice,
There are two pins. One for MIc and other for the headphones.
Use mic only when recording. other times keep it muted in control panel-> sound and audio...
you can use headphone for hearing when you don want the audio stream to be on speakers., TO use so, you have to take of the output from the CPU to the headphone pin after removing the speaker pin or configuring the audio controls control panel-> sound effect manager to have sound always in both theh speakers and headphones.
This requires you to have an appropriate configuration so that all 3 pins are aptly placed fot output from the CPU.
Hope you got what you asked for!
Posted on Apr 12, 2008
No voice
Connect a headset with a microphone. Plug in Red jack in red connector in your CPU/ laptop and try. I wish your explain your problem with few more word. I just give you that much suggest. Because i don't know what's your " No Voice " problem & where.
Thanks.
Feb 04, 2010 | Labtec Spin 45 Computer Speakers
Internal microphone is default, labtec does not
depends on the software you are using, some progs like Skype have settings to change as well as ones in audio control panel
Jul 07, 2009 | Labtec Radio Communications
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Jan 29, 2009 | NorStar Meridian M7310 Phone
Plantronics Explorer 350 speaker problem
Delete the plantronics from your phone, take out the battery from your phone for 10secs then replace the battery and search for your headset again. worked for me.
Jul 02, 2008 | Plantronics Explorer 350 Wireless Headset
Logitech headset - sound
me too! but I am using XP
Oct 06, 2007 | Logitech Premium Headset
Premium usb headset
Hi, A couple of things you can check first pls: 1. the logitech headset has its own mute control somewhere along the line/volume control. pls check/try it on both settings; 2. since it is USB connected, it is now a secondary audio device in your hardware aside from the onboard audio device in your computer. That gives you now 2 speaker output and 2 mic inputs. It is possible that voice recognition uses the logitech therefore it works but voice chat uses the onboard audio and since no mic is connected at the rear of your computer (I am presuming), you may have to set the voice chat to use the logitech mike also. I hope this gives you some idea and works for you. Pls post agin how things are or if you still need further assistance. Good luck and kind regards.
Aug 03, 2007 | Logitech 980374-0403 Consumer Headset
Only one speaker works
whilst the headphones are in use flex the cable from the non working speaker bit by bit down to the jack you should find it will work at some point down the cable as I suspect after long use you will have a break in the cable once this is located just splice the cable and make the break good with a soldering iron, hope this helps
Jul 31, 2007 | Labtec 342 Headset
Labtec C-322 Headset Logo
177 people viewed this question
Top Labtec Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
aravind shet
aravind shet
Are you a Labtec Radio Communication Expert? Answer questions, earn points and help others
