Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Washer leaks small amount. DIY fix: check hoses and ???
Our one year old Profile Harmony washer leaks from the bottom. Seems like more with big loads. Used wrong detergent for a time, but leaks with correct detergent. Will check hoses.
If it leaks due to air bubbles from wrong detergent, should that correct when use correct detergent?
Is there anything else I should check while it's disconnected?
Thanks for response!
  • Anonymous Mar 16, 2014
    water leaking from detergent return hose
    Problem Solver:
  • 5 Answers
Wires found in hose!
When we turned washer on it's side, we found the hose from the pump to the basket had been pierced by two stiff curved wires, still embedded in the hose. Water was leaking around the wires. Wires had come out of an underwire bra! Dealer had only heard of this once before; on his own washer!
MORAL: handwash your bras, ladies.... or pull those wires out each time.
Posted on Apr 13, 2008
Leak underneith washing machine
Tip washer to inspect belts & hoses on bottom. Check hose connections & plastic pump housing for crack.
Nov 04, 2009 | Westinghouse WWS833ES Super Capacity Top...
Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Jan 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water leaks from bottom
check for cracks and corrosion on the outer tub.thats where the water must be leaking from.good luck.
Dec 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
It sounds like your drain hose is kinked or blocked, or maybe the pipe that the drain hose drains into is blocked. Somehow water is now being allowed to get out of the machine at the end of the cycle and is staying in the machine. Check those hoses and pipes.
Jul 11, 2008 | GE Profile Harmony DPGT750EC Electric...
How can I fix my Kenmore portable washer 100.49722990?
Most common cause for water leak
is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Oct 15, 2007 | GE WPGT9360EPL Top Load Washer
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
162 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
