Samsung LE23R will not turn on, stays in standby
My Samsung LE23R will not turn on, it stays on standby, i have lost the remote, it is the feather touch buttons, and they dont seem to do anything, is there anyway to reset or somehting
M
SOURCE: Lost Remote
call spherex416 321 6211 when you call they will say its api (audio products international) and say you have lost your remote to your spherex xbox suround sound and they will transfer you to the parts department or ask to be transfered then tell the person there you would like to buy a spherex remote and the guy told me its about $14and plus shiping he said is $25 idk why shipping is so expensive. but i did not order yet because i dont have my debit card yet and the problem with me was i dropped my remote while music was playiong then it wouldnt turn it on or off or do anything for that matter but the led still lit up along with the ir led because i checked with my camera so im buying a new one i just hope that i broke when i droped it not something else and i took it apart theres like nothing in it that could brake lol i hope this helps it was long i know sorry.
Posted on Aug 24, 2008
  • 9 Answers
SOURCE: my hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Posted on Apr 05, 2009
SD Tech
  • 14553 Answers
SOURCE: can't turn on
When you turn the MAIN off you are killing all power to the set---Some advice---If you Google the model number of this set with the word problem after it you should find what I have seen a lot in these sets: they develop bad solder connections on the power supply printed circuit board---usually the board is about 18 inches tall and 12 inches wide--A number of sites online offer to have you ship them the board and they will resolder it for you.
I have repaired about 12 of these with this problem in the last 2 years---The board has to be removed(there are quite a few plugs that need to be labeled and removed and lots of screws that secure the board in place.)
Maybe not a job for a do it yourself person but the soldering (if it is your problem) will take about 45 minutes(including removal and installing board back).
Like most modern sets this set uses lead free solder and it is soldered(the boards) in a wave or one step process---over time from heat and expansion some connections may crack or even break loose----I would look at the POWER SUPPLY board(follow the power cord as it goes right to it)
If you have any questions or need help please contact me here.
I do this here for free so if this information has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 06, 2009
freetek
  • 5568 Answers
SOURCE: There are two ways of turning this tv off. A
It sounds like a microprocessor that has latched up. Try pulling the AC plug and letting it rest for an hour or two, the problem may cure itself. The end of your message was truncated at ". . . working normally but then it shut . . ." Try posting the missing portion as a comment to your original.
  • 2187 Answers
SOURCE: how to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
Posted on Sep 07, 2009
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
Jun 01, 2015 | Sherwood RX-4105 2-CHANNEL...
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Samsung ps42a456p2 (42 inch plasma) won't power on, stays standby
i'm pretty sure the power supply board is dead. the most common problem with all samsungs.
Oct 30, 2009 | Televison & Video
Technosonic LCD1908 stuck in standby. Does not appear to be flashing red LED as other posts mention. I have no remote. As soon as I switch on it just stays in standby with red LED.
There are several things that must happen before a DLP will turn on. The light bulb and color wheel must start first. Samsung had some color wheel issues. Check the bulb first. If it is good, most likely it is the color wheel.
Oct 14, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
Standby light
I have same problem. Can anyone help?
Nov 03, 2008 | RCA TruFlat 27F520T 27" TV
Can't turn on tv
Unplug the tv for 30 and plug back in.
May 02, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
