Internet drops out when phone rings - Computers & Internet
  • 42 Answers
First I'll assume that you have wireless broadband internet access. In which case the interruption is caused by your cordless phone. Cordless phones are usually 2.4 Ghz now and so are routers. Operating on the same frequency causes interference between them. Get a phone that is not 2.4 Ghz.
If you have dial-up internet access, then this is most likely caused by your dial-up connection being interrupted. Any time someone tries to call you this will happen unless you call your phone company and they can help you take the proper steps to make sure that this doesn't happen (usually that means they'll tell you how to disable call waiting).
Posted on Apr 12, 2008
make sure all your phone's are connected to a DSL filter if they are attached to a wall jack.
Mar 22, 2012 | D-Link Computers & Internet
I cannot answer the phone without pressing the incoming call button that is flashing. I want to be able to answer the phone just by picking up the phone.
From the phone, don't pick up the handset and press PROGRAM 99 then dial 22 and press STORE. Here's a problem. By default, that's what it's supposed to be and if it beeps twice when you press STORE, you didin't change it. Pick up the handset and drop it back down to exit programming.
In order to have incoming line preference, your phone has to be RINGING :-) So, if the first program didn't work, you need to see your system manager to program your phone to ring. Or find an installation manual on the internet.
Carl
May 20, 2011 | Panasonic KX T7220 Corded Phone
How to turn phone on and off-sonyericsson C902, also how to change ring tones
1. Use the call disconnect key to switch ON & OFF your cell phone.
2. To change you ring tones, Select MENU, then SETTINGS, then you will be seeing the GENERAL tab. use the navigation keys to move across the tabs and select SOUND & ALERT. Then Select RINGTONE and you can select your music you needed.
Jun 10, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Thanks!
Feb 08, 2010 | Computers & Internet
I need to change the channel on my dlink 625 router..can u help?
I presume it's a cordless phone? If so, it's possible that it's interfering with the wireless signal. If that happens you will see the wireless connection being dropped - go into the wifi config utility and check how good the connection is. If this is the case, changing the channel may help. To do that,bring the router over to your PC and connect with an ethernet cable (just in case something goes wrong with the channel change and you lose the wireless signal.).
You need to find the "router homepage" in your web browser. If you don't know what it is, in windows click start -> run -> type "cmd" and press enter. In the command screen that pops up type "ipconfig" and press enter. It'll show you a few things. One should say "Default Gateway" followed by numbers.Write those numbers down (probably will be something like 192.168.1.254).
Open your web browser (IE, Firefox etc...) and enter the numbers. This will bring you to the router page. There should be an option like "Wireless" and under there you should see "change channel". It may be in the advanced option window.
IF your computer is NOT dropping the wireless signal when the phone rings, but the internet connection does drop - check the DSL signal light on your dlink. If it is flashing or not on, then the problem is with the DSL filters (small white connectors sent with your modem.). Always ensure any phone on the same line as the DSL is filtered or it will cause the internet connection to drop whenever the phone rings or is picked up.
Aug 11, 2009 | D-Link DIR-625 (790069292637) Wireless...
MY INTERNET GOES DOWN EVERY TIME THE FAX MX310 RINGS
There are some good suggestions here. Check out the solution and follow the steps. The reason dsl seems to be being dropped is the noise in teh line, and as far as I can tell this is a very common problem. Try these suggestions out but you may want to just purchase a better fax machine.
http://www.fixya.com/support/t374109-canon_mx310_fax_noise
Apr 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Please help me!
You could ring or drop into your nearest vodafone or telecom store pending who you're under to send the internet settings to your phone.
Sep 14, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
Recieving / answering phone
i had the exact same problem. basically (sounds a bit weird) but it happens if you drop your fone and the only way to let people hear you again is by dropping it again! so whenever you drop your phone you have to drop it again to fix it.
Jun 14, 2006 | Sony Ericsson T610
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
