Question about Refrigerators
Candy fridge has overnight frozen all its contents but the temperature setting is still on 3, the same as it has been for the last year.
  • Anonymous Mar 20, 2009
    Fridge operates erraticly,freezing contents mainly at bottom of fridge but in time works it way to top.
  • Tczz Apr 16, 2009
    The temp of the fridge has started to drop and all the contents are startign to freeze, we have tried playing with the temp control but it dosen't seem to make any difference.
  • 1,073 Answers
Replace the cold control
Posted on Apr 12, 2008
How do I set my fridge for travelling on my 2016 swift challenger sport caravan?
If unit is dc powered, plug into cigarette lighter receptacle and put ignition switch to accessory on position. Do not use for too long lest you drain the battery. U might have to give the battery some time to recover to start car.
Jun 22, 2016 | Candy Domestic Genuine CANDY Refrigerator...
It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
For more information it may be helpful to look at or contact your local whirlpool support number
May 17, 2011 | Whirlpool Refrigerators
1 is warm.2 is cooler.3 is cooler still 4 is cold etc.(use a fridge thermometer and keep the fridge at +5C,optimum temp)
Oct 14, 2010 | Candy CPCA240FFK Bottom Freezer...
I have a RS643V are the contents in the fridge
The 643V has an issue that it can freeze the water in the line during winter.
You must switch the fridge off until the water starts to run again. Then set the temperature of the fridge up as high as possible in winter. Draw 1 litre of water at least twice a day during winter.
This fixed my problem.
You can set the tempertaure back down in the fridge during summer without a problem.
Jul 06, 2010 | Westinghouse Refrigerators
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Zanussi ZNB 3450S Fridge Freezer not cold enough
it is going into defrost,not enough frozen items in freezer to hold temperature down. if you bought it july last should still be under waranty
Feb 27, 2008 | Refrigerators
Frozen Fridge
the temperature controlis most likely bad since you cant control it. the control is the knob you turn to set the temp with. you should be able to replace it yourself fairly easily.
Dec 20, 2007 | Refrigerators
GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Nov 01, 2007 | Refrigerators
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
