Eclipse AVN5500 Car DVD Player Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The volume will not go up somtimes, when you push the button to incre3ase the volume. The volume will go down when you push the button to decrease the volume. What can I do to fix it?
Anonymous
Level 2:
New Friend:
  • Expert 74 Answers
  • Posted on Jun 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
74
Questions
0
Helped
27793
Points
148
You would have to take it apart and try contact cleaner but I suggest bringing it to and electronics repair center
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
366
Points
The inside of the head unit must warm up before the volume will work. its a precaution to keep it from burning up. after about ten min of playing your radio it will turn up.
Coby 938 theater system volume
bagaimana caranya buka sandi hp expressmusic
1helpful
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
2answers
I have located the volume control button on my monitor but every time i pres it it decreases the volume. I need to Increase the volume not decrease it. Help
You've failed to mention the make/model of your monitor. There should not be a single button for volume control, as volume control is either up or down. Try the button above the one you've been pushing.
2answers
How do I turn down the volum ring on the phone
Check for buttons on the side of the phone. There should be an up and down button to change the volume either way. If that doesn't work look for setting and then sounds. From there, it should be possible to find a way to change the volume of the ringtone.
May 05, 2011 • Cell Phones
How do I adjust the ring volume on incoming calls - I found where it shows where the volume is currently but what button is used to decrease or increase
If it's a cell phone it's usually the button on the left narrow "side" of the phone. From your homescreen try pushing this up or down.
Nov 05, 2009 • Toys
WILL NOT INCREASE USING CONTROL BUTTON BUT WILL DECREASE?
IF THE VOLUME DIAL IS ONE THAT DOES SOMETHING ELSE AS WELL AS THE VOLUME, MAYBE YOU ARE PUSHING THE BUTTON IN WHICH WILL NOT INCREASE THE VOLUME
1helpful
2answers
HOW DO YOU Adjust clock on 2004 ford focus c-max?
FROM THE OWNERS MANUAL
8. Clock: Press and hold CLK button until the
hour digit flashes. Turn the volume
control to increase/decrease the
hours. Press again to set the minutes. Turn the volume control to
increase/decrease the minutes
1helpful
Volume Button on steering wheel not responsive!
There is a metal dome under each button, some time they became warped or inverted and you don't get the actuating contact on the first push but if you keep on pressing it eventually contact will be made and whoalaa actuation happened. If you are technical incline you can replace it with a dome of similar size of a device you no longer have use for, like a remote control, an old car stereo or telephone...ect. Goodluck.
Top Eclipse Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
