Question about Acer Aspire 3000 Notebook
Mousepad need to disable it as it creates problems,external mouse very good.
    Sergeant:
    Champion:
  • 244 Answers
If you want to disable mouse (touchpad), use Fn+F7.
as you said your touchpad create problem, try to remove battery first (boot up using only ac adapter), battery can cause touchpad not working properly.
Posted on Apr 12, 2008
Mouse and keyboard quit working
Can you use an external USB keyboard?
The mousepad may be disabled in the BIOS. Youll meed to get into the BIOS before it boots.
Or it can be driver problem...reinstall the driver..
Jan 18, 2013 | Toshiba Satellite P105-S6064 Notebook
What would cause your mouse not to work at all
Usually the driver is corrupt or the mousepad has been disabled. If you are referring to an external mouse then the most likely cause is usb port failure.
Jan 22, 2012 | Toshiba Computers & Internet
Good evening, I just bought a new Packerd Bell laptop and i discovered a small but really annoying problem. When I am playing a game, I type and using the mouse at the same time. The only thing is when...
Check the mousepad settings in control panel. There are settings and programs that disable the mousepad when typing. A slight brush across the mousepad can send the cursor to odd places in your document.
There is also a small app that disables the mousepad when you type as well. Check your processe in task manager to see if there is such a program running in the background.
Jan 10, 2011 | Packard Bell 160240 Mouse
How to disable touch pad in asus k40IN series? I do not see touch pad settings?
This happend to me on a Asus U81 (Best Buy version of the U80) which has the Elantech mousepad
9.10 includes an X configuration utility called xinput. It is a command line tool. To see the many things you can do with this simply type xinput at a shell prompt.
Start by typing in:
Quote: xinput list This will show you all the input devices attached to your computer. You will need to know your mousepad's id to continue. On My Asus laptop the internal pointer was found as a "ImPS/2 Logitech Wheel Mouse". The Id I get after booting my system with my external mouse attached is 10.
Next you need to know how to disable the mousepad. So you need to know what properties it supports. the command is "xinput list-props" followed by your mousepad's id number, which for me was:
Quote: xinput list-props 10 The "Device Enabled" was what I needed to be able to use to switch it off. On my laptop this line was "Device Enabled (97): 1". The parenthesized number is the properties id number, the 1 that follows it is the value (0 will turn it off).
So now I need to set it such that the mousepad is disabled. My mousepad id is 10, property id I want to set is 97 and I need to set the property value to be 0. The option for xinput is set-int-prop which needs deviceid, propertyid, format of the value (8, 16, or 32 bit), and the value itself. For me this is:
Quote: xinput set-int-prop 10 97 8 0 To turn it back on:
Quote: xinput set-int-prop 10 97 8 1 Since this does its work on the X in memory it is not persistent. If you log out and back in the mousepad will be active again. This is desired behavior for me as I occasionally need to be able to use the laptop without my external mouse.
When I get a little time, I will write a small shell script that can toggle it on or off based on a grep of the output of "xinput list" and bind it to a key combination so I can do this without having to drop out to a script. (EDIT NOTE: See post #15 in this thread if you want the scripts)
One last note, xinput interacts with X. It will not be able to function at a normal terminal screen not running under your X. It will work just fine in an xterminal (the one under accessories menu).
Hope this helps.
Feb 19, 2010 | ASUS K40IN Notebook
Disable mousepad
hi,
try the Fn+F7 combo, the F7 is usually assigned to the touchpad and is indicated by an icon that's relevant.
This works on most notebooks to turn on or off the touchpad.
. Press F2 or F10 (it varies) to enter your bios setup screens. In these pages is a setting for touch pad only, mouse only or touch pad and mouse or serial. You might check that.
Jul 05, 2009 | Dell Studio 1537 Notebook
Mousepad, right clicker problems on ibm thinkpad t41
you can try looking at the manufacturers website for a driver update to your trackpoint http://www-307.ibm.com/pc/support/site.wss/MIGR-46258.html#mouse
Try turning off the tap to click option. This should resolve accidentally dragging things where they don't need to be.
Better option...if you're using this laptop at home just invest in a wireless mouse and set the laptop to disable the trackpoint when an external mouse is detected.
trackpoint=mousepad=touchpad
Jun 10, 2009 | IBM ThinkPad T41 Notebook
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
The cursor doesn't respond to commands given using mousepad.
Sounds like a malfunctioning touchpad. You could try an external mouse and disabling the touchpad in device manager.
Dec 13, 2008 | Dell Latitude D600 Notebook
How to disable mousepad?
normally the Fn and F7 key, it's the key with a finger on a square icon, or right click on the touchpad icon in taskbar>pointing device properties and select device settings and then dissable.
Sep 14, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 laptop
Hi, Try pressing the FN+F7 buttons together. This will enables or disables the touchpad.
Cheers!
Apr 12, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
