No picture or sound. had power outage and when power cae back on, I had nothng.
  • cowboy2930 Apr 12, 2008
    after power failure, no picture or sound.
    no reset button on back. unplugged and plugged back up. same results.
  • 1,512 Answers
Hi there, you could take the back off(after first removing the power plug from the socket). Then check the power supply for a blown fuse. Any more investigation into the malfunction of switch mode power supplies as used in TV require expert attention and should be referred to qualified personal. But do check for a fuse out first :)
regards
Graeme
Posted on Apr 12, 2008
  • 4,889 Answers
OK... that means that the mainboard of the tv is damaged. The cost of a new mainboard will be around 500$+Labor(around 200$). If you are familiar with electronics i can provide you with a schematic if you can provide me the brand and model number of the television..
  • eagle338
    eagle338 Apr 12, 2008
    Well if you want to spend 200$ just to get the problem diagonised you are welcome. I just thought i will help you out but let me tell you i am disappointed by the rating..
  • 655 Answers
Did you check out your power card.
Just remove the power cable from socket
put it again and try out.
My tv clicks to come on but no sound no picture
If there was a power outage the problem is likely in the power supply.
The power light on the front comes on or not?
If no power light unplug the set and follow power cord inside and check the fuses---the click is a power relay activating---set may have up to 3 black relays on the power board.
Let me know your skill level and I will be happy to help.
SD TECH
Jan 16, 2012 | Hitachi 57F500 57" Rear Projection...
We have a rear projection tv that has no sound or picture after a power outage??
Suggest unplugging for 15-30 min to allow capacitors inside to discharge and reset and systems from the outage. Then plug in and see. It could be the power supply or a burned out bulb from the quick pulse of loss of power also.
Apr 26, 2010 | Toshiba 50H82 50" Rear Projection...
Sound quality has diminished after power outage
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
Apr 14, 2010 | LG RZ-37LZ30 37 in. LCD Television
No picture or sound
could be blown flyback transformer
Aug 22, 2009 | Televison & Video
53FDX20B NO PICTURE AND SOUND
It powers up but no picture? In my experience with Hitachi TV's this has been an issue with the convergence IC's failing. You will need to have a technician replace those if needed.
Jul 23, 2009 | Hitachi 53FDX20B 53" Rear Projection...
No picture no sound
You will need to trouble shoot the various power supplies most likely something minor in either the stand by or start up circuits. I recommend that you get a service manual at the following link as they will email it to you and also help you diagnose it with free tech support. Here is the link.
http://servicemanuals.vstore.ca/
Jul 01, 2008 | Toshiba 50A60 50" Rear Projection...
I had a power outage!
Hi there!
Power outages and lightning are the main causes of Electronic failure. It has obviously affected your TV and will need to be seen to by a repair technician if you are not skilled to do so. Regards and good luck, JUS004
Apr 01, 2008 | Apex Digital AT2002S 20" TV
at this point the only thing you can do is take the back off and check to see if any fuses are blown.
Jan 30, 2008 | Apex Digital GB5108 51" Rear Projection...
Tv dont come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | RCA D34W135D 34 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
