Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Can't open up the files I've copied
Hi, I have a Seagate Free Agent go. I was attemtping to back up my computer it's an XP. I opened documents, clicked select all, then copied the docs to the Free Agent. When I plugged the Free Agent into my labtop, also a XP almost all the files showed up in an Adobe file. I have the latest version of Adobe on my labtop, but I couldn't get any of them to open? Said they were most likley corrupted? Help?
Thanks, Jecobie
  • Jecobie Apr 12, 2008
    I think I got booted off from my last reply. Mostly all docs are in Works. I have some important files in Word. I also have some PDF files with books and things. I also have a large mailing list as well in an address book. I hope that is what you need?
    Thanks, Jecobie
    No, only the files that were saved as PDF stayed PDF. The files image look different after saving them to the seagate. some of the files saved look like regular files I see on Works then when you scroll down the file image take on different looks. When you click on it to open and window comes up that says,
    "Adobe Reader could not open ----- because it is either not a supported file type or becuase the file has been corrutped (for example, it was sent as an email attachemnt and wasn't correctly decoded)"
    That is what it says.
    These files were originaly on my desktop and saved in either Word or Works. Once I copied them to the Seagate they were changed and now the little files you go to open say, 'A' on the front or 'Adobe', and some say PDF. If they say PDF on the file they will open. If they look like a plain vanilla file they will open. But all of the other files that say A or Adobe on them will not. I get the "you can't open this file", window.
I use Adobe 7. I have Windows Vista and I have transferred PDF files from my HDD to usb successfully working with same 32 GB USB key. All seemed fine. until my pdf files started not to open anymore (to go to the same usb).
Then I decided to upgrade to Adobe 9 to see if the problem came form the Adobe version I used. This resulted in doing the same thing, i.e. cannot still open my files.
Result: All my pdf files open on my HDD, all of them also opening from the USB key (no problem so far) except those I recently added to the USB key. It's been a few days that I have this problem. I feel stuck because all of them can open from my HDD but no longer from my USB key.
Does anyone have any suggestions?
Many thanks,
T
Posted on Feb 26, 2009
  • tinoun Feb 26, 2009
    Many thanks,
    T
    President:
  • 1,944 Answers
In what format are your documents before the backup?
Posted on Apr 12, 2008
  • Damen Wong
    Damen Wong Apr 12, 2008
    Do you mean to say that all the files that you backed up turned in PDF files?
Had a seagate free agent given as a present but i have lost the manual and don't know how to operate it. how do I transfer files and how do I download them onto another PC ?
Hi vic_barnes,
You don't need the manual to operate the external hard drive , all you need to do is connect the drive via the USB cable and your computer should accept it , and then you would find a removable drive visible in your my computer option.
Then you can open this drive and copy your files to and from it.
Hope this helps ..:)
Sep 03, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
How to transfer files to the seagate external drive
attach the seagate open windows explorer click on my computer if you can see this seagate free agent select the files you want to transfer right click copy navigate to the seagate select it then right click paste or select the files right click send to seagate
hope this helps
Nov 02, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cant open my vista backup files on my windows 7
Bro you can use VLC player for that file: follow this steps: 1. install VLC player in your system: http://filehippo.com/download_vlc/download/6e22d5996625004973958dff5998c5e1/ 2. Run or Launch the desktop short cut icon for vlc. 3. Grab the file into VLC player. (this player can play also support a file format .flv) 4. Your done!. God Bless.....
Apr 13, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
How do I transfer files to my seagate free agent?
Just left-click the file or folder you want to copy, choose copy.
Open My Computer and find the external drive, double click, once the folder opens just right-click and choose Paste.
That's pretty much it....or you could also drag files / folders to the drive.
Hope this helps.
Nov 24, 2009 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
Seagate Free Agent Go Problem
Install the seagate manager on a different computer and decrypt the files there first then move it back to your computer using the basic copy/cut and paste.
May 27, 2009 | Seagate FreeAgent Pro 500GB External USB...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Can't open files copied to my Seagate Free Agent Go
Ok, install Office onto your laptop and see how it goes. Don't be too panic striken Microsft in general allow one copy of the same program to be running on a desktop and a laptop at the same time on the same license.
It's a home/work thing, Laptop goes to work, desktop stays at home and you can't be using them both right =)
Apr 13, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
139 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
