Optoma h77 parts
Where i can get optomal main board and power supply for optoma model h77
  • Anonymous May 23, 2008
    my inbuilt power supply of "VPL -ES3"is not working due to high power flutuation that cause the 6-standing pins ic in the output session to burst off completely that its value can't be regconized.I really want to have that value that could replace.Also, is it the lamp that has a short which blew off this IC?
  • cavsnumber1 Aug 11, 2008
    did you ever find any spare parts for your projector. I need a power supply for a Sharp XR-1S. please let me know if you had any luck.
I have a H77 that needs a new color wheel and assembly. did you find your parts or are you interested in selling your projector to me for parts?  john_stevenson4@hotmail.com let me know
Posted on Mar 25, 2009
  • 563 Answers
Hi there
You will have to locate your nearest spares dealer on the net.
Posted on Apr 15, 2008
RCA 55" TV Model: TV LED55C55R120Q Serial: 4526-LE55C55-C201218, August, 2014 Diagnosis and repair recommendations needed.
like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 13, 2016 | Televison & Video
Im trying to figure out where the led driver is on a sanyo tv model fw48d25t.Is there any way to tell if it is in the power supply board?The part number for the power supply board is 02-sps39a-c010000
Aug 10, 2016 | Sanyo Televison & Video
Is the Backlight inverter and the power supply unit in the same board for this tv?
May 18, 2016 | Televison & Video
Optoma HD70 bulb failure
I am betting that the ribbon cable to your color wheel has become loose. Here is a detailed slide show of a similar model so note where the cables are and check each one.
Optoma HD20 DLP Projector DMD repair turning green and flickering
Jun 25, 2013 | Optoma HD70 DLP Projector
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
Optoma rd65tv will not turn on
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck....
Mar 21, 2011 | Optoma RD65 65" Rear Projection HDTV
Optoma Projector power LED is blinking green,funs are not working, lamp not function, how can i solve this problem
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
Dec 02, 2009 | Optoma HD65 DLP Projector
On my optoma H77 I am replacing a burnt out bulb with a New one. The ''TEMP'' light blinks immediatly without the projector getting up to normal opporating temp. Is there a ''Reset'' button ?
clean out the projector with canned air to get rid of the dust that could be causing it to overheat. also make sure the fans are spinning. if it still blinks, replace the temp sensor. if it overheats alot, the sensor will wear out from excessive heat.
Nov 07, 2009 | Optoma H77 Multimedia Projector
What is part number for main power supply board on a model#d52w20 rca
you have to open the TV up and it should be on a white sticker on the mother board.if you do not find it google RCA model #d52w20 main power supply board
Aug 26, 2009 | Televison & Video
Optoma H77 - Lamp shuts off after coming on for 5-10 minutes
Hi SoonerJDP
This is indeed a warning that the hours on the lamp has been used up and that you will have to replace the lamp.
Remember to reset the lamp timer once you've replaced the lamp.
May 18, 2008 | Optoma LFU250E Projector Lamp for H77,H79
553 people viewed this question
jasbo
jasbo
