Question about Acer Aspire RC500 PC Desktop
Acer RC500 power supply problem
Hi am tansfering system from an acer rc500 to a custom box. Am havingrouble getting power from the motherboard any ideas as to why?
  • frank507 Jan 10, 2009
    I have exactly the same problem and tried evrything as described in the given solutions. No result was achieved. My computer is now down more than 5 days and still does not start up when pushing the power button. it is although clear that the power supply is OK.
Migregorio,
You are awesome. My computer has been down for days and I have tried everything. It was charging, AC adapter and batt were fine but it would turn on for a few seconds and then shut right off. I unplugged everything, pressed power and wouldn't you know the stupid thing turned right on. Thank you.
Posted on Oct 21, 2008
  • 42 Answers
I experienced this very thing today. Disconnect everything and then reconnect. Make sure that every connection is accurate and also make sure that the spacers, or gold screws in between the case's body and the motherboard, are in place. If the fans are starting for a split second and then the computer shuts off then this should fix your problem. Otherwise if you're using all of the same components I can't think of any reason this should happen.
Posted on Apr 12, 2008
How do you get into the back of an acer 25700 to change the fan?
http://www.manualslib.com/manual/1376/Acer-Rc500.html?page=11#manual
If your computer is under warranty should it be done by a qualified service if You not want to lose the guarantee.
Jul 12, 2014 | Acer Aspire RC500 PC Desktop
What is an acer rc-500 power supply rated at in watts?
The power rating of the switch mode power supply is printed on the label attached to the power supply.
Aug 25, 2011 | Acer Aspire RC500 PC Desktop
The hdd has failed on my acer rc500 pc.
You can get the drivers from this link: http://drivers.softpedia.com/get/TV-Tuner-Co/Others/Acer-Aspire-RC500-RC900-TV-Tuner-Driver-5131243.shtml. Or chose your OS if required and then download it....................sodeep
Apr 30, 2009 | Acer Aspire RC500 PC Desktop
My Acer RC500 don't start up anymore.
Check the motherboard for obvious bulging capacitors. If you don't see any you still might have bad caps. Additionally you may have a faulty power supply.
Mar 27, 2009 | Acer Aspire RC500 PC Desktop
Upgrade Acer RC500
hi all you have to do is do a bit of research on your pc then see what is upgradable. im sure if you go to the acer website you can find out a bit more about your pc.
Jan 27, 2009 | Acer Aspire RC500 PC Desktop
Need to change motherboard fan on acer rc500 any help?
if the fan is above the cpu then there are 4 screws holding it in that have to be removed. Then unplug the fan wire. Make sure you purchase the same fan size to replace. Then reinstall with the screws. Make sure your pc in unplugged when you do this.
Jan 16, 2009 | Acer Aspire RC500 PC Desktop
No poer to computer
You cannot change a power supply unit on a computer, you will damage the whole computer or you can even fry yourself.
Buy a new computer.
Jan 11, 2009 | Acer Aspire RC500 PC Desktop
AcerAspire RC500 shutting down
hi
check your power supply waltage.
check your earhing.
check power cable condition.
Mar 26, 2008 | Acer Aspire RC500 PC Desktop
ACER ASPIRE RC500
The driver for the TV Tuner that came with your system is Leadtek Winfast TV2000 Download the driver at this link under the TV Tuner Driver catagory. Hope this works for you http://support.acer-euro.com/drivers/desktop/aspire_rc500.html#driver
Sep 10, 2007 | Acer Aspire RC500 PC Desktop
An Interesting Problem
It sounds like the CPU is overheating. When the system boots up, can you hit the DEL, ESC, or F12 key to get it into BIOS mode? Often, there will be a setting in there to monitor the processor temperature. If you can get it into that screen, leave the computer in that mode and keep checking the temp. Make sure the machine itself has good air circulation and isn't in a hot spot in your house (for example, where sunlight hits the main box) If it continues to flounder, you'll probably need to upgrade the CPU fan or install a heat exchanger fan...
Aug 23, 2006 | Acer Aspire RC500 PC Desktop
Acer Aspire RC500 PC Desktop Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
