Question about Philips Magnavox 9P6034C 60" Rear Projection Television
8P6051C101 I just recieved this Tv From a friend and i assembled it and pulged it in. It started sparking and there were flames seen in the rear of the Tv. This seem to come from a singular line from what I could see that went one of the lenses (if looking from the back its the one all the way to the right) My question to you is does this need professionally done or can I just replace the line and it will work? Please advise
  • 1 more comment
  • winggoon Apr 12, 2008
    It is a red wire and it looks like it is arching at the oppsite of the lense like a white box were the rubber seal is the model number is 8P6051 C101 sry the link made me put the 9P6034 But the correct Model Number is the 8P6051 C101. It looks like it is arching to the wall beside the wire. I hope this helps and thanks for the info already.
    I wouldn't be able to do that until tommarrow I have to got to work but the chasis number is PVT810- AH01 I will try to get a pic tomarrow thanks again
  • winggoon Apr 15, 2008
    the wire seems to be fixed i turned it on but now there is a green tint that is ever present in the screen can you help with that?
  • Philips Master
  • 8,617 Answers
I take it that you are refering about the large red wire running to the Blue CRT (picture Tube) as thats the one on the right side looking in the back. Can you tell me exactly where its arching at on the wire? I should be able to help you out with it, as its probably the flyback ( where the red wire plugs into with the other red wires) and if so its an easy repair and I can psit a link where you can order the part and get free tech support plus instructions on how to do the repair yourself. I am one of that sites repair techs. Let me know where the arching is going on also let me know your correct model number as there are two model numbers associated with your post. the 9P6034 and the 8P6051 so I will need the correct model number
Posted on Apr 12, 2008
  • Sonny Berry
    Sonny Berry Apr 12, 2008
    Can you look on the back of your set and find the chassis number and let me know what it is and I should be able to tell you where you can get the part you need. can you also post a picture of the item your refering to as it could either be the flyback or the HV block a picture would let me know exactly which part you need.
  • Sonny Berry
    Ok sounds good then I can give you the exact part to get and you will be able to fix your set. Either part is very aesy to replace.
Will not start. Engine will turn over.
check basics (1) is there fuel getting to engine . TEST BY PUSHING IN VALVE IN FUEL RAIL AFTER CRANKING ENGINE if fuel comes out test for spark
Oct 08, 2014 | 1994 Toyota Pickup
Where are the spark plugs located on my 2003 Saturn Ion
Hi Carol,here's a link on how to replace your spark plugs.
Mar 22, 2013 | 2003 Saturn ION
Lg 42 plasma - loud bang/spark smelly smoke and small flame inside.
It is a short circuit caused by some components and/or power capacitors. This may need assessment by a qualified service technician.
Jul 30, 2012 | LG 42PG60 42 in. HD-Ready Plasma TV
How to tune up this car
change your spark pulgs, pulg wires, air filter, and fuel filter. that would be a good start now do you want to know step by step or what to change
let me know
stockam auto
Jul 15, 2011 | 1998 Toyota Corolla
Purchased range used. Burner Head assembly with
Yes, you need a burner cap to sit on top of the burner assembly and create the normal star shape flame.
Feb 09, 2010 | Kitchen Ranges
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
We don't have any flame.....it turns and blows but no fire I have a Kenmore Model 11070902990 Ser. # MK 0612958
This is the flame sensor that you probably need.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 03, 2009 | Dryers
T.V. turns self off
This is a common problem. May people have been noticing in the back of the television large sparks and flames are being thrown. The unit then detects overheating and turns itself off. Please report this problem to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
https://www.cpsc.gov/cgibin/incident.aspx
Jan 21, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Flashing
Pop and flash meaning that the picture turns on and off? Many people's tv eventually just turns off all together. Furthermore, if you notice a crackling sound, it isn't just the sound of the tv turning off, it is the sound of sparks and flames emitting from the back of the television. Take notice of this as it is a fire hazzard. If you do notice this, please report the problem to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
Dec 02, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52 in. Rear Projection HDTV-Ready
Please report these problems to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
Aug 06, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
