Question about Miele Washing Machines
Technical fault f53 on Miele Novotronic W 1511 washing machine
  • 82 Answers
SOURCE: Door stuck closed on a Miele Novotronic W+862!
does the machine have water in it if so the door will not open check filter
Posted on Aug 02, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
  • 70 Answers
SOURCE: My Miele Novotronic W 844 Washing Machine will not
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Posted on Mar 30, 2010
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
SOURCE: manual for Miele Novotronic W502 washing machine
Maskinen er sperret
Posted on Nov 25, 2010
How do I fix a F53 fault on a Miele W3740 Washing Machine
First, unplug the washer for minutes then plug in and see if it solve the problem, if not then check the carbon brushes on the motor. These are a part which is expected to wear and when they do the motor cannot rotate the drum, which means the speed sensor thinks something is wrong and throws the error.good luck. Fixing an F53 on Miele washing machine
Nov 02, 2017 | Miele Washing Machines
How do I fix F53
This is a speed sensor fault. Could be caused either by the motor itself (built-in speed sensor) or by an electronic fault.
What is most likely depends on your model. See Miele goedkoop repareren cheap repair preiswerte Reparature
Mar 03, 2015 | Miele Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
What the meaning of f53 ptoblem?
Error code F53 on Miele is a speed sensor fault.
It has detected the drum speed to be wrong at some point and has indicated the problem to you.
Have you tried unplugging it. That will reset the computer.
If it's not coming up again after unplugging it, I'd not worry about it.
If it is coming up every time you use it, then you have either a faulty sensor, motor or pcb.
Miele are extremely secretive with information on their appliances and this makes it hard to diagnose accurately faults on them.
May 16, 2011 | Miele Novotronic W1930 Top Load Washer
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
May 21, 2010 | Miele W865 Front Load Washer
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
1,125 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
