Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Component Video Problem--Again
I'm about at wits end with this set. Long story--I'll condense as best I can. TV purchased 12/04. In 11/06 I hooked up a HD cable box via the component video jacks. No signal. (I had never used the component jacks, so was not sure they ever worked.) After weeks of troubleshooting by cable co., local TV repair co., and Mitsubishi Tech., it was determined that board #930B924002 was bad. After $621 replacement, the TV worked for 2 weeks--then back to the blue screen. (All other inputs have always worked fine.) Mitsubishi then decided it must need an entire new chassis #955B298001 ($1,015). The day I was to take the set back in for the repair, it began to work--out of the blue, with no tinkering--so I didn't take it in. Now, 15 months later, it has quit working again. Do you know what is happening and if this is common with this set?
  • 3 Answers
Had to get my chassis replaced for similar reasons. it was still under warranty so i lucked out. however i was out of a tv for 3 months off and on because of all the troubleshooting that had to be done before Mitsu said replace the chassis
Posted on Apr 29, 2008
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
I need a manual for an SD310VU MODEL it was given to us but we do not know what we need to hook it up to our TV. Can you help us Thank You
Toshiba has the manual for the SD-310VU at their site: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2841310&rpn=undefined&modelFilter=SD-310VU&selCategory=2797338&selFamily=2797344 .
You can connect the DVD player to your TV either with composite video (AV), S-video or component video cables. For the best signal output, get component video if your TV supports it. So the issue is what inputs do you have on the TV. For an older TV with only a coaxial antenna input, you would need an RF modulator for the composite video cable. (These are available at shops like RadioShack.)
Composite video cables usually have 3 RCA plugs on each end (yellow for video, red and white for audio). S-video uses a different plug and then the audio is carried on a different cable (usually red and white RCA plugs). Component video cables use three wires to carry the video (YPbPr - usually colored red, green and blue). As with S-video you use a second cable for the audio.
Purchase the cable(s) that will give the best signal with the inputs that your TV has and connect the video outputs from the DVD player to the matching input on the TV. Connect the audio out of the DVD player to either the TV's input or your sound system receiver, depending on the speakers you want to use.
I hope this helps.
Jun 16, 2011 | Televison & Video
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Jun 10, 2011 | Audio Players & Recorders
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
Tried to hook up hd cables and seems good but no audio tried to hook up but can't get to work
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" The DVD, Receiver etc, to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
How do I hook up a nintendo wii to 604 via component wires.
There are several ways to do this. Here are the two most common.
The best results will be provided by connecting the component cables directly to your TV, including the audio cables of course, and then connect a separate pair of cables from the TV "audio variable out" to the audio in on the receiver.
However, if you do not have that option then connect via component to your 604 to inputs on the panel labeled "component video in." Then, connect from the monitor out section of the 604 via component to your splitter, cable box etc.
But again...the BEST option is to connect directly to the television as that method provides the least amount of signal loss and you only need one additional set of cables for audio to connect from the TV to the receiver instead of an additional set of component cables which are often more costly.
Jan 01, 2010 | Onkyo TX-SR604 Receiver
When we watch a dvd on the dvd player hooked up to the vision tv the picture is black and white only. Why?
Make sure you match the color coded from the DVD player to the tv set. Yellow is video, Red is right audio, and white is left audio. Or you can do component, which will give you best picture. Component has five ends on it. There is a red, green blue for the video, and red and white for the audio.
Dec 28, 2009 | Vizio L37 Television
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Having trouble playing my Ps3 on a non HD tv after already using it on a HD tv
Hey bro try going down to circuit city, best buy and get the HDMI cord that converts to a Component cable on the opposite end. You can do this as long as the back of the non H/D tv has the Component Inputs on the back of the TV. If that does not work get the HDMI cable that converts on the opposite end to a S Video signal and connect that end to the S Video input on the back of your tv. I have seen these cables at circuit city in the playstation section. Again on one end of the cable it has your HDMI input to connect to your ps3 and on the opposite end of the cable it has the S video plug to run to the back of your tv and plug it into the S Video input. Same thing can be said for the HDMI on one end of the cable and the Component cables on the opposite end to run to the back of your tv. This will work if you find those cables. Good Luck.
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
No signal on screen in VCR mode
I assume your plasma set has one or more auxillary (component) inputs, and to one of these is where you should hook in the VCR. You will have a video input jack, and a set of audio input jacks (probably 2 for stereo) for each of these aux. input sets. While exact setups differ, depending on your cable box(es), DVD players, and whatever other equip., a likely hookup is from the VCR video & audio outputs to one set of the aux. inputs on the plasma set. When you want to use the VCR for playback, you must select that particular aux. input with the plasma remote. Some of the hookups these days get complicated by all the equip. some have, but the above is at least a start. Thanks
Mar 13, 2007 | RCA VR622HF VHS VCR
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
156 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
