My MP3 player hasn't been working for over a month and I can't figure our why. When I press the power button the blue light around the control will light up but nothing will appear on the screen (it just stays black as if the power was off). Help please!
Mine did that the day after i got it, try holding down the 'on/off' button for ages eventually it lights. You have to hold it down for a while though.
Hope this works.
You may need to now reset the player, that may have been a bit much for it.
To reset your Sansa Mp3 player.
Slide and hold the Power switch up for approximately 20 seconds.
Release the Power switch.
To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
Sansa Mp3 player frozen? How to reset and...
Hi, I experienced the same problem this morning, my sansa player (e280, 8Gb) froze in the middle of a song, the screen went blank but the wheel still had its blue light on and i didn't know how to fix it bur then i figured how. If that's the case with your player too, then the solution will be to press and hold the power button till the blue light goes off (abt 8-10sec) and then just restart the player. It should work.
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first.On most models, restart is done by holding the power button in for 15 seconds or longer.Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
It seems like your E250R is experiencing a temporary system error due to a corrupted song, and needs to be reset.
Try to "Soft Reset" your player, press and hold the "Menu" button until the LCD light and scroll wheel light turn off.
Since the player was probably left on for more than 7 hours (as you indicated), you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours.
Next, try to format the player to rid of any corruption then re-transfer the songs. If you have subscription songs, then I would suggest to delete the song you last played which caused the error.
I hope this helps. There is another solution for the player, but for now this might actually resolve the issue. Let me know the results. :)
