Question about Bose Lifestyle 38 DVD Home Entertainment System System
Bose Life styles NTSC to PAL
I accidently changed the setting to PAL from NTSC the bose system says to see the tv but the tv dosen't support the format and says see bose system... how do i change back form PAL to NTSC
First, using the remote Turn the unit off.
Then, using the remote Turn the unit on.
Next, Press the [System] button
Next, Press the [Right] Arrow (once)
Next, Press the [Down] Arrow (4 times)
Next, Press the [Up] Arrow (once)
Next, Press [Enter]
Last, Press the [System] button
Done
Posted on Mar 22, 2010
  • Lillian Cyr
    Lillian Cyr Dec 13, 2010
    Having gone to Pal accidentally, I was lucky to finally get back to ntsc by blindly following the suggested procedure of bittytitty - THANKS, you made my day! G.C.
I called technical support and they told me, in the unit, to hold enter and press the store button twice. This way you will get the menu options in the unit. Use the volume button to go to NTSC progressive or whatever option you want.
Posted on Jan 18, 2010
I had the same issue and spoke with technical support. If you hold the enter button on the unit and press the on/off button. It bring the on screen menu up on the unit, instead of the TV. You will then be able to use the volume buttons to move the settings from PAL to NTSC.
WIth the unit off-Make sure to hold down enter, within a second press the on/off button. But do not remove you finger from the Enter button. You may not get the timing right the first few times.
Posted on Feb 02, 2009
  • 472 Answers
How is the Bose connected to the TV?
Is it via AV leads or s-video HDMI etc.
Your TV although it does not support Pal, should be able to display an image all be it in black and white so you can change the settings back.
The easy way around it is to change your TV to PAL, there should be an option in it's menu to do this. Just about every TV in the last 10 years has had that option so the manufactures did not have to set it for different countries themsleves..same applies to the 240-110volt power supply. You may also have an option there for Auto (which rarely works)
If you can supply the exact model number for the TV as well as the Bose I will hunt for the manuals and have a look for you.
Hope that helps =)
Posted on Apr 12, 2008
My Bose lifestyle48 system will only play dvd's in black and white. I changed cables but no different.
Your Bose System may not be on the the right video format.To change the format, press "system" button on your remote and scroll to video settings option.Go to video and choose between NTSC,PAL and MULTI to see which of these format works for your TV.
Feb 11, 2017 | Bose Audio Players & Recorders
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
I cannot play NTSC DVD's on my Bose system
thats because your region is for PAL-SECAM. Your unit cannot recognize this format unless it has been programmed to automatically play NTSC & PAL-SECAM.. Browse the menu and try switching to NTSC format. hope this helps ;-)
Feb 04, 2011 | Bose Lifestyle 38 DVD Home Entertainment...
I NEED HELP CHANGING MY TV VIDEO FORMAT BACK TO NTSC I THINK I CHANGED IT TO PAL OR MULTISTANDARD. I HAVE NO PICTURE SO I CANT SEE MY SETTINGS . CAN U PLZ GUIDE ME THREW THEM.
Download the manual from :-
http://www.bose.com/pdf/customer_service/owners/og_321_2.pdf
Page 47 would have the explanation.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 22, 2010 | Bose 321GS Series II System
Color when watching a DVD
Maybe you need to set "TV SETTINGS" in your DVD unit menu (i.e. PAL / SECAM / NTSC)?
Jul 13, 2009 | Bose Lifestyle 48 System
Changing to NTCS to PAL. I've accidently changed
If you haven't solved this yet, just turn off the system. Press and hold the enter button on the front panel. While holding enter tap the store button a few times until you see "Video: PAL ###" and change this back to "Video: NTSC"
Apr 19, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Picture on my Bose Lifestyle 35 is jumping around
Hi
Replied you on premium post as well.
Please change TV color system to AUTO to see jumping free picture.
If Bose is either on PAL or NTSC color system, TV will show correct picture and color automatically.
Feb 08, 2009 | Bose Lifestyle 35 System
Need to perform factory reset
When I worked for Philips, I solved one of these. First, try unplugging the unit from the wall outlet for one full minute and see if that alone will reset the unit/restore it to defaults. If not, make sure you have a yellow video connector running from the Bose to your TV rather than another type of video cable - change the tv to the appropriate source channel - now see if the menu will appear. If not, you will have to fly blind (don't mess up): Press the System button, then the right arrow by the Enter key twice, then the down arrow by the Enter key five times, then press Enter. Defaults (including NTSC) will now be restored.
-Tha Mp3 Doctor
Dec 30, 2008 | Bose 3·2·1 II System
Switching form PAL to NTSC
did you tried to switch back to factory settings? thanks
Apr 11, 2008 | Bose Lifestyle 38 System
Dvd is showing black and white
You are running in the wrong format.
If you are in the USA then you need to set the Bose system to NTSC. If you are in another part of the globe then set it to PAL.
The other thing is to make sure your TV is set the correct way as well. The only other thing that will cause this is if you are trying to playback a PAL dvd on an NTSC system (and the other way around of course)
All the options you need will be in the setup menus for both the TV and Bose.
Hope that helps
That should solve your problems.
Jan 21, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Bose Lifestyle 38 DVD Home Entertainment System System Logo
1,530 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
