Question about Refrigerators
How to turn off icemaker - Refrigerators
  • Old-N-Slo Sep 04, 2008
    Maytag MZD2766GEW. The icemaker stopped working. The dispenser for ice and water works fine. Was looking over the icemaker and slightly moved the unit and water started to dispense and existing ice cube were ejected. Unit stopped again from producing ice. Maybe be a loose elec. connection I could check and before I call the service tech. The bottom mounting screw wasn't a problem but to unhook/latch the unit from the side posed a problem. Is it a latch or is there a screw unseen to remove it from the side(top part of icemaker)? Is there a service manual that depicts on the method of removal?
    President:
  • Refrigerators Master
  • 2,651 Answers
Genally there is n arm thatyou can click in the up position, or a switch indicating on/off to temp diasable your ice maker
Posted on Apr 12, 2008
We have a Samsung side by side. Ice maker on the top as part of frig. water is leaking and I see the ice stopper is not closing to keep the warm air from entering the ice compartment. Any ideas
If the icemaker is leaking water onto the floor:
  • Turn off the icemaker and then turn off the water supply to the icemaker. See Icemaker On/Off Switch.
  • The water supply line is usually located under the kitchen sink.
  • Locate the cold water line and look for a small 1/4" copper line attached to it. Where these two lines meet, there will be a saddle valve. This is the shut-off valve. Turn this valve in a clockwise manner until it stops. This will shut off the water to the icemaker.
Aug 11, 2017 | Samsung Refrigerators
Why does water drop before ice is made?
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Mar 28, 2016 | Refrigerators
Serial # k15004707 model # mf12665xew3 french doors ice maker in upper left corner. After the ice maker fills with water it drips off the front side.
May 05, 2015 | Maytag Refrigerators
How to fix a kenmore ice maker leaking water
Feb 20, 2015 | Kenmore Refrigerators
Ice maker leaking water
Jul 14, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
How can I turn off the icemaker. I don't need it.
There should be a lever by the icemaker or switch you can turn.
Dec 01, 2009 | KitchenAid KSCS25FKSS Side by Side...
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
1,003 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
