Question about D-Link DCS-1000W Personal Web Camera
DCS-1000w through Dlink DIR-655 router
No matter what I seem to try I cannot access the default configuration page for this internet camera. I had no problems with my previous Dlink router. I have reset the camera but cannot access the default page at the supposed address (192.168.0.20). I have also tried connecting via a laptop and cross over cable while matching the ip address range but this did not work either. I cannot ping the address from any LAN computer, camera does not appear in IPView software (tells me it's an invalid IP address when adding a camera). Setup wizard does nothing at all and detects no camera. Anyone who can help me with this I would sure appreciate it. Thanks so much.
Mike
  • 2 more comments
  • jageesh May 04, 2008
    I have this camera and router. I can see it via ethernet at the camera ip address, but as soon as I disconnect the ethernet I cannot access it wirelessly. I called Dlink and they tried changing the router to 802.11b, setting it to WEP since the camera is not WPA compatable, and removing security altogether. None work. Dlink came back on the line to say this camera is not compatible with this router. I find it hard to believe that they would not have a work around for their own product. I think someone out there is smarter than Dlink tech support. If yo're out there, please share your solution!!
  • elias97 Aug 11, 2008
    I have the same problem but I have four dcs-900 that worked well for a year and now this, Any help would be greatly appreciated! I can't get to the cams! tried the reset, can't ping can not get access to the ipview se! please HELP!!!
  • Moomins Nov 20, 2008
    I have the same problem as the first post above - a lot of money for a pile of rubbish!!!!!!
  • Majeed Panahi Jan 13, 2009
    IPview (Version 3.4.1. 200306 12000) will not connect to the DCS-1000W , although if I do an automatic search it actually finds and identifies the Camera IP address , its name , model number and the MAC address correctly. However , when I choose this camera , it refuses to connect saying "Invalid IP address!"
    I am using Windows Vista Buiness.
    I wonder if this old version of D-Link IPView has problem with Vista only. Anyone tried IPView on Windows XP?
    Problem Solver:
  • 4 Answers
These cameras are touchy. Hold the reset button on the back in for about 20-30 seconds. Bring up the CD software you got with the camera, it should spot the camera right off and you can configure. That seems to be the only way I can communicate with this model. After setup, then browsers, etc seem to work fine. I would also download the latest Firmware and update.
Posted on Jan 10, 2010
I've plugged the modem into the router and the four lights on the left of the router are on, the middle two blinking; however, despite being able to detect the router wirelessly I am not able to gain...
One thing to try is to hard reset the modem and the router. This will work on an unprotected router that won't connect most of the time.
This link is to the data sheet d-link gives for this router. ftp://ftp10.dlink.com/pdfs/products/DIR-655/DIR-655_ds.pdf
This one is to the software and instillation guides they provide. Select your country from the three. Then there is a link to a FAQ below the two download links that will help you find which of the two that you need.
http://www.dlink.com/products/default.aspx?pid=DIR-825&tab=3
Jun 18, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I have a DLink Dir-655 router. It seems drop a lot.
try to configure your Internet connection settinngs and router cables
Jun 07, 2010 | Computers & Internet
When I type 192.168.0.1 into a browser I am taken to the www not the router. Default gateway has not been changed. I am attempting to access a D-Link DIR-655 Wireless Router.
this address is correct for ur router now u go to network connection u change ur ip address to ip automatic i think u can access to page configure dlink, if have problem email to me billy_nguyen57@yahoo.com
Jan 15, 2010 | D-Link DIR-655 Wireless Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dlink router with hughesnet
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
Apr 26, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless dlink dir-655 router not working. I installed the router using the Installation Wizard that comes with the installation CD. Everything seemed fine. But at the time I wanted to start surfing the...
just off the firewall or proxy server or anti virus for configuration time and just connect the cable to the LAN port of the router and other end to the PC then try to open the configuration page of the router go to the explorer or Mozilla there you have to type default ip in the addresss bar 192.168.1.1 or 192.168.2.1 try both which is the open then go it after that in cd user manual is there just go through it.
Apr 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DCS-1000W Personal Web Camera Logo
832 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
