Question about HP vs15 15"LCD Flat Panel Monitor
Panel doesnt turn on
Hi there when i turn on my computer everything seems to work but when i turn on the panel it stays black. please help im in need of my computer
  • 42 Answers
First check all of your connections (power as well as video connections). If they are all secure, then make sure that if there are multiple inputs that you have it on the correct input (by cycling through the sources with the corresponding button). If none of that works then look carefully at your screen to see if you can make out anything on the screen. Sometimes if the LCD inverter goes out then everything is VERY dark. Hope this helps.
Posted on Apr 12, 2008
Problem: no image, black everything, it doesnt turn on, there is no red light and no green light either, previously sometimes turn off and than went on again... it did it several times... I can buy a...
Unplug the cabels and plug it back in,Have you tried this already?
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 10, 2011 | ViewSonic VP2030b 20.1" LCD Monitor
Hp laptop doesnt boot it is always black and nothing shows up
Its probably caused by the RAM, have it checked. If you can do it yourself, remove the panel cover underneath the laptop and clean the RAM as shown in the image below:
(The actual RAM in your laptop is shorter than the RAM on the image.)
Install it back to the computer and turn it on. If problems persist try another RAM, it may already need replacement.
Please reply if this has helped you. Thanks.
Oct 26, 2009 | Computers & Internet
Laptop wont turn on.. at all.... Aspire 9300
Hey whats good I had the exact same problem with my computer. Im not a computer wiz or anything so I asked for help to and these a-holes told me i had to pay 200 just to talk to someone for 30 minutes!!! Fu** em!!! All I did was change out the power cord. It seems crazy as hell but it worked for me and Im up and running I hope this helps you out. Any questions contact me at noxx3577@gmail.com
Jul 27, 2009 | Acer Aspire 9300 Notebook
Toshiba Satellite Goes completley off! Black screen, NO POWER!
Hi Steven, in my experience as a tech support agent, it seems that you're having an issue with your hard drive, sometimes it might also be an overheating issue, to be clear on that, please be sure to check the temperature of the computer when it shuts down, then the first symptom of the issue seems to be the clicking sound which ussually comes from the hard drive's reading head, this might indicate the hard drive is damaged and that it cannot perform as usual. The steps to troubleshoot the issue will be as follows; First please enter the BIOS/ System Setup of the system, by pressing the [Delete] as soon as the computer turns on several times, you will appear in a black or blue enviroment with some information from your computer. Check if the issue will happen there as well. Second, if the computer gets really hot at the point when it shuts down, please ensure that all the fans in the computer are running (you should be able to hear them), And be sure of the temperature when it shuts down, we must know if the computer is too hot to touch, or there is no problem with it. Third step, how long will the computer stay on? Will it always shut down at the same time?
The best solution for this issue would be to replace the hard drive, or defective fans depending on the troubleshooting results, if you're still within your 1 year warranty with Toshiba, you should contact their tech support team to replace the part.
As an aditional step to the troubleshooting you should also try to remove the hard drive, and let the computer on for as long as its necessary, to discard the hard drive from the issue, if it doesn't shut down then the hard drive seems to be the problem.
May 03, 2009 | Toshiba Satellite 1805-S274 Notebook
The env2 is a great dissapointmant
You will have a one year warranty so you can get if fixed for free.The problem is Your display is dead! Both the panel and the LCd screen. I advice that you pressure them for a replacement since its the 3rd time. Either ways you can get it fixed/replaced for free.
Good luck,
Sai.
Mar 12, 2009 | Verizon Communications enV2 Cellular Phone
Sansa e280 fatal failure - black screen, unrecognized by comp, won't restart..
1. turn sansa clip on
2. slide to "hold"
3. press and hold center button do NOT let go...
4. plug in the connector cable
5. wait until computer recognises Sansa device
6. let go of center button
7. drag n drop files and you are all set
if that doesnt work you will need to go to the sandisk website to update the firmware on your device..
let me know if you anymore questions..
Please rate accordingly
Thank you
Computerrep
Oct 31, 2008 | SanDisk Sansa E280 MP3 Player
Hello
hello, it seems that your laptops vga or motherboard is damaged and so it wont start up. repairs required, a new motherboard costs from 100 to 1000 usd
contat your dealer, or a local professional / toshiba.
Mar 30, 2008 | Toshiba Satellite A135-S2276 Notebook
G25 wheel not responding
Hey! I had a similar problem! Only the weel tried to calibrate itself, but itjust "twitched"
So I tried replacing the power cord with a similar one from an older wheel. Didn't work for me.
I opened it up and voilá, same problem as "epicname"! I tightened the screws on the optical sensor and put it back together. Now it works like a treat! So i guess if it's the power cord it won't react, If it's the optical sensor it will twitch, notice it doesn't get a signal and give up from there.
I don't know if this will really help anyone, as they would just send it back to the shop and get it fixed for free. But couldn't find the reciept, and often find it's better to fix things myself than to let the local shop send it to their usual place.
THIS IS JUST A LAST RESORT!! ALWAYS TRY TO GET THE WHEEL REPLACED OR FIXED PROFESSIONALLY!!!
Remove all the screws underneath, even the larger black ones. Remove the steering wheel by unscrewing the bolts on the front panel and the three larger screws under the little circuit board in the wheelhub.
Remove the bonnet. theres a black box on the left engine wich contain the sensor. If it's loose you're able to rattle it. If you're not, the sensor is most likely not the problem.
Unscrew the mainboard and remove the bracket it sits on.
Now the Force Feedback rig should be loose.
Flip it over and pop off the little black cap on the sensor(it's just pushed on)
Put some locktite on and fasten the two screws that hold the sensor mount (unscrew and remove the sensor board so you can get to the last screw)
Put everything back together.
Sep 15, 2007 | Logitech G25 Wheel And Pedals Set
HP vs15 15"LCD Flat Panel Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
