Question about AO Smith .75 HP Uniseal Vertical Motor
I am looking for a wiring diagram for the three capacitors on my 7.5 hp single phase motor. The make is AO Smith, Part Number: 7-348524-05-0J, Frame: F215T, Stock Number: V305. Can you tell me where to get a wiring diagram to connect these capacitors.
    President:
  • AO Smith Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
I sent the number to my AOSmith tech contact. I hope to have it monday sometime. Please contact me thru our site, www.arrowmotor.net, so I have your email address to forward the connection diagram to.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 13, 2010
  • John Prohaska
    John Prohaska Jun 14, 2010
    I do not believe I received your email so hopefully you find this...
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
I purchased a 60 gallon compressor from Lowes which has a 230 volt single phase motor,3450 rpm,15 amp. The model # of the motor is 7-194160. There is no wiring diagrm in the manual. I was wondering where I...
There may be a wiring diagram either on the body of the motor or inside the wiring terminal cover.
A.O. Smith can be contacted at 800-262-6484. If you do call, have pertinent motor info ready.
Nov 30, 2010 | AO Smith Air Tools & Compressors
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I look at the A.O. Smith Motor Master University manual and my question concerns the diagram on page 50, Single Phase Motor. In need to operate my motor with 115V and my understanding of the diagram is...
That is correct...if you have done that and still have problems post a comment that includes a description of what is happening and the motor model and serial number for further assistance.
John
Aug 25, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Oct 21, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Shop idiot took motor appart unhooked all internal wires and didn'tmark where they went. do you have schematic for 56H single phase 1 1/2horse wires ?
Please contact me thru www.arrowmotor.net using the contact form and include the model number of the motor and we can get you the exact diagram for the motor in question.
Aug 08, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Start Capacitor wiring diagram needed
When hooking up capacitor on a pump it doesnt really matter which way the wires go. The capacitor is set up in such a way the it supplys power wherever the wires are hooked up. I hope this helps
Jun 02, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
AO Smith .75 HP Uniseal Vertical Motor Logo
544 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
US Parts Center
US Parts Center
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
