Question about Brother MFC 210C All-In-One InkJet Printer
Can't Scan The box says it is connecting to the PC but it does not happen and I cannot scan!!! Help? swil@valstar.net
  • 813 Answers
Hi friend
u need to reinstall your scanner driver then after try to scan
Posted on Apr 12, 2008
I have a kyocera cs-1650 and am trying to scan to pc. I have scanner file utility installed, yet it shows no connected scanners in the status box. How do I get scanner file utility to recognize and...
You have to make a folder on you computer to scan to. you have to configure the scanner file utility with the path to that folder. You have to setup the scanner NIC with a sender ans a destination. The destination has to point to the PC running the scnner file utility by inputting the computer hostname or IP. The scanner nic can be configured with your web browser by putting the scanner NIC IP in the address bar. You have to make sure your firewall is not blocking the file scanner utillity. For more help go to www.gfbm.net.
Dec 31, 2009 | Kyocera Copystar CS-1820 Black and White...
I press scan but nothing happens I scan on cannon Mp 160 and I cant scan with my pc
Make sure the scanner is connected to your laptop/PC before you press 'scan' and is turned on.
Pressing the scan option will start Canan's software MP Navigator for scanning. You can also start MP Navigator on your PC and then start scanning directly from your program or from the printer button.
Dec 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Whenever anything is downloading to my computer my sound gets garbled. This especially happens when I am trying to view streaming video. The sound gets garbled and out of sync with the video which also...
You are basically driving your PC pedal to the metal, as video and audio are the two most bandwidth-intensive things to do with a PC. Couple that with the Internet connection, and the prerequisite virus scans, and the poor machine is about to throw a rod.
Having said that, your machine should be up to the task, it sounds as if your data stream is inconsistent, and you have some other processes interrupting your "flow".
Make sure you defrag your HDD, jumping around to find places to sore data can cause this also.
Make sure all of your system's drivers are up to date, especially video, audio, and NIC drivers, and consider the following,
You are on the 'net, so your anti virus app, if set to "on Access control", is checking everything coming into and going out of your box, creating delays and timing hiccups.
Try this, disconnect from the net, turn antivirus off, and watch a DVD. if you have no problems, then it is most likely your real-time data flow from the net crashing into your antivirus scanning everything. Second most likely is data "throttling" by your ISP, those schnooks sell more broadband than they can deliver, and so they use "packet-shaping" to slow everyone down a bit.
Perhaps you can change your antivirus to "on demand scanning" , and scan manually, instead of automatically, while watching streaming, then go back to "on access" when you are finished..
Perhaps better to download the video beforehand, scan it, then watch while disconnected from the het, and "on Access control" turned off.
Nov 30, 2009 | Computers & Internet
Display reads "connecting to PC" nothing happening
Was this function working fine before? When you choose Scan => To Email, what the device actually do is launch the scanning software and scan it and save to temporary folder THEN open your default OUTLOOK email account and creates a new mail with the scanned file attached to it. So it could be a scanning software error or low in memory since the process requires an amount of memory.
So you better try to Scan => To File and see if the scanning completes. If you have problem with it, then try to reinstall the program of your printer and scanner in one.
Nov 01, 2009 | Brother MFC 490cw Color Inkjet...
I can´t scan with HP LJ3015 /WIN XP PELASE HELP ME
When you installed it you should have a new program under "start", "Programs".....maybe "HP scan utility" (or something similar) to open up the scanner dialog box -it may even be an icon in "my computer", then put your document in the machine and select the scan from your PC, rather than the control panel of the machine. This is how I used my previous HP scanner -never from the unit itself.
Mar 12, 2009 | HP LaserJet 3015 All-In-One Printer
I can't scan
When scanning documents on my MFC 7420, this is what I do. Place document on th scanner bed and don't press any buttons, leave it whatever mode it is in. Go to the computer and click on start> program files> scansoft paperport> open paperport se. When paperport is open click on the scan icon in the upper left corner. A dialog box on the left hand side will ask what you want to scan a picture or document. Select accordingly and press the scan icon.
A new window will pop up and ask what you want to scan and the size. You can either select pre scan or scan. The computer then will send a scan request to the scanner. When it is done scanning close the second window that popped up and the document that you just scanned will be there with a red box around it. Click on the document and it will open, then you can edit and save as needed.
Happy scanning
Hatter1
Jan 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
Pc freezing up
There is a strong chance that you got something nasty which keep connecting on the net when you
are using these apps.
I suggest an online scan with Kaspersky and a malware scan asap.
Nov 16, 2008 | Computers & Internet
Windows explorer
This could be due to a spyware/virus. Have you tried running a virus scan? As you can still get online try an online virus scan: http://www.pandasecurity.com/homeusers/solutions/activescan/ click SCAN PC NOW
Sep 02, 2007 | Acer Aspire E380 ASE380-UD500A PC Desktop
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
