Net gear router troble shooting problem.
Our house is supposed to be wireless net work, but there is no connection in any part of the house, except of one room. Please let me know what is going wrong and what should I do?
May be the set up is not right?
Thanks, Frieda
PS: router number is: 166257761A632
MAC......00146C000D8E
  • Anonymous Apr 15, 2008
    Hello mark:
    There is a problem with signal all around the house. Only one room has a internet signal,but signal should be all around he house.
    Thanks, Frieda
  • Mark Kessler May 11, 2010
    Is just one computer able to access the internet from anywhere in the house, or you can only access the internet from the one room?
    Sergeant:
    Champion:
  • 427 Answers
Mirrors, thick walls, and metal objects can block internet signal from going into certain rooms. Make sure that you are in a good room for this.
Posted on Apr 15, 2008
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
I HAVE TURNED MY WIRELESS ON AND KNOW IT PICKS UP CONNECTIONS EXCEPT FOR THE ONE I WANT TO CONNECT TO AND IM SITTING RITE NEXT TO THE MODEM FOR ME WIRELESS INTERNET AND IT DOESNT SEEM TO FIND IT HOW DO I...
It seems you are having issues with the router. As you've said your PC can detect other wireless networks except for wireless network that you're supposed to connect into. Try contacting the technical support team of the manufacturer of your router so that they can check it out, it might be a defective router.
Sep 10, 2011 | Computers & Internet
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Toshiba M35X-S311 laptop that wireless will work anywhere but not at the house, have a linksys router. Everybody else can come over and connect wirelessly to my router but when I turn my wireless button...
First You can not connected the net by Safemode.
Second, Use the wire, connect the Linksys to your computer, and if you are using another modem, set this first using same SSID and password.
Then remove the cable and set the wireless (Before That while cable is on see the wireless on linksys home page and access it. to get your key number or set it up.)
If you can not, try to see Cisco systems user guide.
JMC
Aug 15, 2009 | Toshiba Satellite M35X-S311 Notebook
Net gear was completely disconnected from computer. net gear WPN82r v 2 was inadvertently reset. dont have a password. any help
To bypass the wizards, connect the router via an Ethernet cable, log in from a DHCP enabled (IP & DNS) computer at
http://www.routerlogin.net/basicsetting.htm
User name is admin and the password is password, both in lower case letters.
Note that wireless connectivity is off by default. When you configure this router manually , remember to turn the wireless connectivity on.
Jul 11, 2009 | NetGear RangeMax WPN824 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
I have a prsario 2100 notebook with a Belkin wireless g notebook card I am tryin to connect wireless through netgear router and it is not working
configure the netgear router.
connect the net gear to the internet cable.
see back of the router for information.
and then configure the net gear. and the usermanual of the netgear.
may this help,
melnavz
PS: pls donot rate me if the solution won't help but if this resolve rate me fixya.
Jul 03, 2008 | HP Computers & Internet
Laptop does not connect to wireless
is it new or old laptop? try to remove and reinstall the wireless lan driver
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
