Question about Xerox Phaser 7300DN Laser Printer
A Very light Grey shade/Ghost like residue on glossy paper but not reg paper
I have a Xeroxx 2135 and Lexark c534
Ive been thru the whole freaking manual and tried different gloss paper.
Whenever I print a color sheet with white areas - the white areas have like a very lite grey cloudy tone to them. but when i print on reg paper it doesnt happen. I tried numerous glossy paper and even the manufacturer type and it does that - i would go to kinkos print that same piece and it would be fine - id take the exact paper from kinkos and print on my printer and get the grey tone.
I called the manufacture and they said it need to be serviced - but i get no error message and the supplies are all 70% + - plus the warranty ended :(
any help
  • RMC01 Feb 07, 2009
    exactly the same symptoms and attempted fixes.
    does anyone know what the cause or potential fix is?
    rmc
  • Anonymous May 16, 2009
    Same issue
    Scholar:
  • 49 Answers
Have a look at the link below. When ghosting occurs it's usually because the last image printed has not been cleaned away properly. However, on this machine the image is put directly onto the paper rather then an image transport. Have a look at the link below and then remove all the parts and clean away any loose toner and check the paper transport under the toner and image cartridges, remove it and make sure it's clean. Also ghosting can happen because of a timing issue on the machine, power down for 1 minute and reboot just to be sure. Good luck!
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=311,E=0000000000024639749,K=1510,Sxi=17,Case=obj(79049)
Posted on Mar 30, 2009
    President:
  • 2,072 Answers
I have looked and this problem confused me to no end.
I started searching through engineering notes from Xerox and found this line which I am copying and pasting.
This is not my opinion I can send you the entire report if you wish.
But sadly here is the answer.
Although supported, glossy paper will exhibit background toner and is a limitation of the printer technology.
Posted on Apr 14, 2008
  • Rick Kasper Apr 14, 2008
    Here is additional information I gleaned.
    TROUBLESHOOTING TIPS AND HINTS:
    Visually inspect the imaging units green coating for a dusting of toner that may indicate a flipped cleaning blade. Check the operation of the fans in service diagnostics. Specialty medias (glossy, coated, cardstock) will show more background toner. - this is a limitation of the printer technology.
    REPAIR/INSPECT/PREVENT PROCEDURE:
    1. Clean feed rollers and exit rollers only when dust or
    debris is visible.
    2. Clean the LED assemblies.
    3. Check version of print engine and image processor
    firmware; as appropriate.
    4. Check cleanliness of interior and exterior of printer,
    including fans; if necessary, clean (dust or vacuum) these
    areas.
    5. Review proper operation of printer using a customer
    file, if possible.
    6. Review with customer all work that was performed; also
    discuss how to properly care for their printer.
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Printer is printing double images of documents
The best test to find the defective component is a "half-test." You interrupt the print job by opening a cover. See if the drum/ toner has produced the defect already, or if the defect is created at the end of the print process.
The most likely suspect would be the fuser producing ghost images every 3 inches in a repeating defect that fades out.
Make sure that you are not using thick or glossy paper on the wrong setting. The toner won't bond if the settings are too cold.
The Brother part number for the fuser is LM6313001K for the white connector. If you have the grey connector it will cost slightly more. They are not compatible, so be sure to match the connector when ordering.
Whit
Item, Inc,
Nov 02, 2010 | Brother HL 2140 Laser Printer
Xerox 6350 prints ghost page every page printed. It is printing a ghost imge of the previous document printed on every page.
If the ghost is black then you might have a bad Black Developer 116-2011-00
If the ghost is in all colors then it may be your fuser, or possibly just your paper settings. (If you are using glossy paper or card stock this needs to be fed from the MPT tray and defined correctly in the control panel)
Whit
Item, Inc.
Oct 13, 2009 | Xerox Phaser 6350/YDT Laser Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Imagerunner 1023if printing on glossy paper
Hello boriquajake,
We are looking at inherent limitations of the copier. The reason the paper appears "glossy" is that it is coated with a type of plastic that does not like going Thru whats called the fuser. This fuser does what its name implies as it "fuses" the toner to the paper by way of extreme heat and pressure. Thru decades of trial and error copier manufactures have found a way to make carbon black and plastique( like the EURO NAME?) along with other confidential compounds into a mixture (called toner) that can survive the extreme heat (370' F and above) and pressure (the sky is the limit here) bond to the paper and successfully exit. However, the nifty glossy paper was designed for an inkjet printer which uses sprayed ink and neither heat or pressure. My final most helpful statement would be that glossy paper was never designed for a copier. And I can promise you that at some point the glossy paper will cause a paper jam in the fusing area that will be very expensive . Since the "gloss " is merely a plastic shine that was never meant to be "re-melted" by the rubber coated rollers......... need I say more. One day you will have a paper jam from hell that will destroy the fuser. I wish I had better news but if you think about it I just saved you a service call, and a significant bill. You are are the working guys/ gals like me that I like to help before you get screwed. Take care.
Jul 19, 2008 | Canon imageRUNNER 1023iF Black and White...
Problem with phaser
Phaser 2135 Printer: Resolving dirty looking background or gray haze
Description: Tiny speckles of toner scattered all over the page, even in areas of the page that should be blank.
  1. Make sure the media being used is supported by the Phaser 2135 printer.
  2. Inspect imaging drums for any signs of leakage or excess toner that could be falling onto the print as it travels though the printer. Any leaking imaging drums should be replaced.
  3. Verify environmental conditions. See article Dealing with humidity, humidifiers. If the environmental conditions are not within the specified range, the printer should be moved before trying to troubleshoot the cause to the background toner.
  4. Determine if any of the imaging drums were exposed to light for an extended period of time (more than 10 minutes). If so, then Replace the imaging drum. (Xerox is not responsible for any imaging drums that have been damaged by over exposure to light.)
Additional Recommendations:
Background toner may increase, if printing occurs at temperatures towards the higher end of the specified operating temperature range. For this reason, it is recommended that the printer be moved to another area if at all possible.
In addition, very smooth media types such as glossy; allow toner to more easily scatter about the page prior to becoming fused. Try using a less smooth media if at all possible.
Feb 08, 2008 | Xerox Phaser 2135N Laser Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
Xerox Phaser 7300DN Laser Printer Logo
918 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
