Question about Sony STR-DG510 Receiver
Right rear speaker has static
the right rear speaker has static coming from it. I have switched the speakers, and it is the receiver causing the problem. Any suggestions for what components to check?
    Sergeant:
    Champion:
  • 319 Answers
Sounds like damaged channel in output circuitry. Take to pro/tech
Posted on Apr 21, 2008
Right speaker channel doesn't sound clear anymore
If it sounds like static, and the bass really effects the sound it is most likely going to blow.
I would suggest taking it easy on the volume or switching your volume settings so its more on the left speaker than that right, but still with sound coming out the right one. Just so you don't blow it as fast.
Nov 17, 2014 | Audio Players & Recorders
I purchased theses speakers January, 2011. At first they worked fine. Then I started having problems getting sound out of the left speaker. The sound would return when I plugged and unplugged the speaker...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 04, 2011 | Bose Companion 2 Series II Multimedia...
Why is my left speaker coming out with no sound, but my right speaker (no controls on it) is working? To note, when I move the cord that plugs into the sound source, I hear crackling in the left speaker...
is the cord you move laying on a rug or carpet this will cause static
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 23, 2011 | Juster AC-691 Computer Speakers
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Apr 14, 2009 | Yamaha HTR-5730 Receiver
Purchased a jeep with pioneer dehp6600 receiver.
Remove the speakers and trace the signal pairs (wires) to their origin, maybe they are still factory harnessed where you can access a connection point behind the head unit. Here are the factory color codes .
Hope this helps
Aduz
JEEP up_arrow.gif P o w e r Memory (+12v Constant) Pink Ignition (+12v Switched) Violet/White Ground (-) Black Illumination Orange Dimmer Blue/White Power Antenna
S p e a k e r s Right Front (+) White Right Front (-) Black Left Front (+) Green Left Front (-) Black/Yellow Right Rear (+) White/Black Right Rear (-) Brown Left Rear (+) Green/White Left Rear (-) Brown/White
Mar 29, 2009 | Pioneer DEH-P6600 CD Player
Pioneer VSX 816
The rear signal is generated and separated internally, if either the processing is not correct or the rear channel amplifier has a problem, you can get this type of behavior. Does the static happen more often at higher volumes or is it purely random? Does changing the volume make the static louder or is it always the same level?
Dan
Mar 18, 2008 | Pioneer VSX-816-K/S Receiver
Car audio
zeus_s007- This is a pretty technical,request so i hope you understand my instructions. I hope the harness plug is present,this makes it easier.First of all i'll give you the wire colors,there are a couple the same color and we will start there.
tan-left front speaker-positive
gray-left front speaker-negative
light green-right front speaker-pos.
dark green-right front sreaker-neg.
brown-left rear speaker-pos.
yellow-left rear speaker-neg.
dark blue-right rear speaker-pos.
light blue-right rear speaker-neg.
orange-12volt constant-memory
black-ground
yellow- 12volt key switched-may be bigger than yellow speaker wire-we can check the wires,will explain later.
gray - dash dimmer
brown-dash dimmer
You don't need the last 2 mentioned,any others left over not needed.
The safest way to check the 2 brown,grey,and yellow is to use a AA battery, as a speaker tester.You take the colored wires for the speakers and touch the AA battery to them. For example you know the 2blue ones are right rear wires-so take the AA battery and touch one blue to the one end of the AA battery and the other end to the other blue wire, you will hear static on that speaker.This will let you know the 2 proper wires for the speaker,no static -wrong wire.you only have to do this for the grey,brown,and yellow wires.Well I hope I don't confuse you,if your not sure,let me know.Good luck, happy wiring.
cooltek Mar,5/08
Mar 04, 2008 | Audio Players & Recorders
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Sony STR-DG510 Receiver Logo
243 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
