Akai LCT42Z6TM only the HDMI input works
The only input on main input board that works is the HDMI. This seams to have been a factory defect. Any ideas??
    Problem Solver:
  • 4 Answers
I have the same problem any solution yet
Posted on Jun 25, 2008
Both hdmi inputs dont get a signal?
Unplug,replug the tv back about an hour later.Than go to the tv menu go to PICTURE go down to reset.The Tuner board should reset back to the factory setting,all ur HDMI ports hubs should function now,not than ur Tuner board is defective must be change.Tries websites Like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement,
May 19, 2010 | Akai LCT3785TA 37 in. LCD HDTV
My HDMI inputs #2,3, & 4 no longer work. I have my Direct TV hooked up to the #1 & my Playstation 3 hooked up to the #2. The # 1 still works, but the others don't. Idid try all of them out also....
Unplug the tv about an hour to let it reset itself.Replug,reset everythings in ur tv menu back to factory setting.All ur functions on the Tuner board should work again.Not than,ur Tuner board is defective,have all those shorted HDMI input Hubs.The only way now it to replaced the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Without a coax. imput , how do i connect my cable
You have to use a cable box using the Red, Grn, Blue outputs along with the red & white audio, or use the HDMI if the box and your set has it.
Apr 08, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Akai LCT42Z6TM Problems. Help?
I'm working on one now. So far, I've found two capacitors on the power supply board bad, both 1000uf/16V 105 degree caps location EC9 area. Still have mild interference on the screen which seems to change with the type of video being displayed.. Will look for C301 next, is it on the signal board?
Jan 08, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Random red washout
We had the same red "pixilation" problem with our new Vizio 47" set. Read within this site for our solution (posted by Cavanaju): Call Vizio and have them come out and replace the LVDS cable and the main board. They will have to order and bring in the parts, which will involve them unscrewing a million screws to take off the entire back of the tv and replace that calbe within it all and the main board. It will then be just fine! (I hope...we just had ours fixed 4 days ago and so far, so good...) Hope this works. Seems to be a factory defect they have had with this set. Good luck!
Jun 10, 2009 | Vizio VO47L 47 in. LCD TV
My Akai LCT42Z6TM TV does not have a coaxle
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Apr 23, 2009 | Televison & Video
I have this akai tv model lct42z6tm and connected to a vcr video output to the video input of the tv.it works for about 2 minutes and suddenly it shows grayish horizontal lines and the it scrambled all...
You may have bad capacitors on the main board where the signal is processed. These caps are as labeled: c280,c323,c302 and c320- replace this one first (it usually fixes the problem) Replace these caps with 100uf @35V
Feb 21, 2009 | Akai LCT42Z6TA 42 in. LCD Television
MY BLACK COLORS ARE RED
steenson
To be honest with you. Do not waste your time change the main input board, your problem is solved. Because the main input board coul be defective. I can help you get the input board. Please, my e-mail Stevebuy31@hotmail.com
Dec 10, 2008 | Akai PDP4225M 42 in. Plasma Television
Akai LCT42Z6TN
I had the exact same problem already and my LCD is less than 8mo old. One of the techs from AKAI told me that its a known problem and many tv's were coming back "unserviceable". They now have a "supposed" fix for the problem. I only hope it really works and its not just a "carry-over" until the warranty ends. I am beginning to think its a quality issue and the units may just be defective. Thismay be thier way of doing a quick-fix vs. recalling all those tv's. This is what he gave me to as a solution to give the serviceman when he comes to fix the LCD.
AKAI model LCT42Z6TM: If there is no image or a badly distorted image with horizontal static lines, usually with four boxes in all four corners of the screen, there is a possible fix for this. There are four capacitors on the main board that have been identified as the primary cause of this symptom. Replace the capacitors at location numbers C280, C302, C320, C323 - 100UF 35 VOLTS [dxh]
Dec 12, 2007 | Akai LCT4216 42 in. LCD Television
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
