Nokia 6300 Cellular Phone Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nokia 6300 stopped vibrating even when the vibrate alert is on what do i do ?
edwin botio
Level 3:
  • Nokia Master 624 Answers
  • Posted on Jun 12, 2010
edwin botio
Nokia Master
Level 3:
Answers
624
Questions
0
Helped
153012
Points
2119
Open your phone and get your phones ********..if you have a tester ,test it if working ,if not replace it with a good one..by the way your ******** located besides your phones charging pin and headset interface..its color is green..
i hope it will help you..thanks
Vibration not working
Please go to Profiles section.
Select General -> Personalize -> Vibration Alert -> Select "On" instead "Off".
After doing the changes Activate the profile.
This will solve your issue.
Thanks,
Amar
1helpful
Deactivation of vibration in nokia 6300
to turn vibration alert of go into profiles scrol down to viration on or off and choose. if your saying that it wont vibrate then your small ipc motor may be burned out and need to be replaced.
good luck
7helpful
Vibration problem of nokia 6300 i want solutions
Does the vibration not work when a call comes or is it vibrating non stop? In either case you need to restart your phone and try calling to it to make sure it vibrates.
If it is not vibrating, then check phone ringing settings and make sure it is set to vibrate + ring.
2answers
Nokia 6300
go to profile->general->options->personalize->go down to vibrate alert on.
My phone wont vibrate even its been activated
its not broken, if you go to settings and turn application settings to default, the games vibrate, also, reminders vibrate, so there must be a setting telling the phone not to vibrate but i cant find it
2helpful
Vibrate alert nokia 3110 not working
I think the ******** in your mobile phone is disconneted or not working. Try opening the phone and see for yourself.
May 06, 2009 • Cell Phones
Mobile phone
u better go to the technician for repair the problem of that is the buzzer
94helpful
22answers
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
85helpful
6answers
2helpful
VIBRATING ALERT DOESNT WORK
Open the unit and clean the contact on the vibra and check the vibra to see if its stil ok. Use an eraser to clean the contact.
Jul 24, 2006 • Nokia 3220
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
