My washer will not start when I pull out the dial. However, it does work on spin. It is about 30 years old. Could it be my dial that is defective? I live in Ottawa , Ontario and would like to know the closest Maytag repair shop. Thank you, Deborah (nannydeb02@sympatico.ca)
    Genius:
  • 1,073 Answers
You can call whirlpool Canada for a list of service companies,as fo the washer issue that you have remove the inside 2 phillips screws on the top of the console and lean it forward, with the power off check the fuse in the console small glass one, if it is blown it will not let the machine fill with water. if it is blown then you will also need to replace the water fill valve, the fuse is seeing high amp draw from the valve and this blows the fuse. A safety thing
Posted on Apr 12, 2008
Washing machine does not spin in any cycle
Hello, It can be one of two things, the contacts in the dial can have worn or broke causing the relay not to open or close to activate spin cycle.
Most likely it is your transmission or main gear for your spin cycle.
I hope its the dial which is an easy fix, but the trans is a big project IF the washer is worth it. You may consider looking for new/used washer if trans is bad. Good Luck.
Dec 11, 2012 | Roper Washing Machines
SPEED QUEEN WASHER WON'T ALWAYS AGITATE
see this causes:
Lid switch
test for open or defective use the DVOM OR VOM
Motor coupler
COUPLER wears see the diagram
Belts
broken or worn replace
Clutch
clutch worn replace
Drive motor
bearing and winding burn in one directionor defective by overheating
Drive pulleys
drive pulley frozen or worn replace
Transmission
broken gear or worn
Agitator
can be worn too replace
Jun 21, 2012 | Washing Machines
Samsung vrt washer not draining
I've had so much issue with this washer since I've own it and it hasn't even been a year..I just finished fixing the same issue you have with your washer. I had to drain the washer which you were right very messy. My problem was one of the wire came lose. Of course it was from the water pump that was attached to the tub...Who would design something like that.
May 20, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
