Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital antener. all works but I can't get any channel 9 stations no matter how many times I rescan channels?
My remote broke m i got a universal 1 but i cant get the code for it. Its a NU - TEC nue 2601
help plz
Posted on Feb 24, 2013
    New Friend:
''Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital ''
Poor English!
It should read; ''Bought a Coles $259 Nu-tec DVD/Tv combo, brought it home and set it up with a indoor digital ......''
Posted on Aug 02, 2012
  • Stanislav Myerjinski Aug 02, 2012
    Poor English!
    Brought is past tense of Bring!
    Bought is past tense of Buy!
    I simply fail to understand how these words can be used incorrectly!
SOURCE:
SOURCE: Trying to set up Digital Labs 19
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Posted on Mar 19, 2010
HDTV GURU
  • 261 Answers
SOURCE: Digital channels off the air on Sharp LCD Tv
Yes, Go into menu and make sure you have at least rabbit ears hooked up and preferably a HDTV Antenna. If not, a Large paper clip will work in a pinch if you have one, but it won't pick up all channels. Give that a try and then go into the menu under search digital channels then, after you find a few, see what the signal strength is and go from there. Let me know how it works out for you and please give me a good rating. I am trying to do this to make some cash as well. Good day and happy HDTV ING. JAY
Posted on Feb 01, 2008
blueextc3221
  • 15935 Answers
SOURCE: Local channel went digital, lost signal.
You need a digital to analog convertor box to recieve the digital signal.
All UHF+VHF signals will be digital starting in June.
Thanks for using FixYa - a FixYa rating is appreciated.
Posted on Feb 20, 2009
wikkidd420
  • 96 Answers
SOURCE: Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
Posted on May 16, 2009
SOURCE: Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Posted on Oct 10, 2009
I got a rca home theater older model TV....how do I program it to receive digital channels using and indoor rca HD antenna
Let's assume this is a digital TV, not one of the old analog home theaters. First hook up the antenna. Then go into the TV's setup menu. These vary by model in their choices and the names they use. Find the section of the menu that deals with "input" or "home." You're looking for a choice of "cable" and "antenna." Choose "antenna." There will also be a selection that tells the TV to "scan" for channels. That's what you want it to do. Typically this takes anywhere from 30 seconds to a couple of minutes. Once the TV has found all the channels available, you can exit the menu. From then on it's a simple matter of using your remote to choose the input you want to watch at that time: TV (from the antenna); Cable (if you have a box plugged into another input); DVD etc.
A note on antennas: indoor ones tend to have VERY limited range. They will get reliable reception only on local stations with high-power transmitters. My brother lives in Maine, miles away from the nearest tower, and his indoor got just one station consistently, but with lots of dropouts. A $35 outdoor one got four, three of which were reliable. He bought a better one for about $90 and now he gets 7 or 8, all but one of them consistently.
May 23, 2014 | Audio Players & Recorders
Bw7080 remote to a nu-tec tv & dvd comb
Just buy one universal remote control, which have setup codes for your brand combo. You can get this detail by the code list accompanied with the remote control. Brand isn't matter.
Apr 30, 2012 | Televison & Video
I just bought a nu tec tv and it won't tune into any stations please help
T uner of signal module needs replace. Check and see if you have signal going to your video input.
Apr 09, 2012 | Televison & Video
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
Nu-Tec TV/DVD Combo
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sep 03, 2017 | Televison & Video
Can't recorder digital broadcast
Hi,if your vcr is an analog machine then you will not get a signal.If you have a seperate digital box then you can connect this via a scart lead to av2 on the vcr.Best thing though is to buy a digital dvd recorder.hope this is of some help.jamie
Mar 02, 2009 | Zenith XBV443 DVD Player/VCR
My new TV is set for cable. I do not have cable, I have an anten
Sansui TV's come from the factory set for CABLE. If this is a HDLCDVD320, you will have to go into the menu to change the signal type to AIR, then run the automatic search to program in your channels. Their free customer service line is 800 289 0980.
I hope this helps.
Dec 28, 2008 | Televison & Video
Lost digital signal on analog TV
You do not need to use an RF modulator if you have a LG DR787T. It will output the program on channel 3 or channel 4. If you have another recording machine, I think you may need to re-scan for the stations.
It is also possible that you need to use the remote to switch from the analog (66 only?) stations to the digital stations.
If using a 787, press HOME, select TV & press ENTER, the channel list menu appears. With the highlight on the top of the list, use the < and > arrow keys to select from: TV, DTV, Favorite, or ALL. This lets your pick whether you want to see digital, analog, favorites with the "HEAR" symbol, or all stations.
tom
THIBSRUS:
I think that there is a selection on the Panny that works much like the TV/VCR selection on a videotape recorder. Your machine is receiving and decoding digital stations, as you stated you can see them on the menu screen, but is not passing them through to your TV set for viewing. To use the Panny as a tuner for live TV shows, or actually, programs currently airing, you have to tune the TV to channel 3 or 4, or, if using the Red/White/Yellow connectors, the proper video input selection, AND turn the Panasonic on, and have it sending the programs it is receiving out on the antenna connection or the video/audio out (RWYellow) connections. It is really a matter of selecting, on the Panasonic, whether it passes through the antenna signals, or the digital signals that is is receiving.
tom
Nov 14, 2008 | LG DR787T DVD Recorder
Televison & Video Logo
915 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
