Question about Logitech Harmony 550 Remote Control
Blank screen on the Harmony 550
One minute the remote was displaying all the needed messages and next nothing is displayed.  I changed the batteries and that did nothing.  Everything continues to light up but there's nothing on the screen.  Even the programmed automation works but I'm doing it from memory and not because I can see anything on the screen.  Any idea what's going on?  Is there a way to reset the screen without losing my programming?
  • 12 more comments
  • muzzu Apr 16, 2008
    I have the same problem, even though the remote works fine I have to do everything from my memory of what is what.. as the display is gone completely blank.
  • jkauffman May 18, 2008
    Have either of you found a solution - just happened to me..
  • tb40nd May 23, 2008
    Same here! Lights up fine and controls the devices but there's no words anywhere! WTF?
  • Anonymous Jul 02, 2008
    Just happened to me..... :(
  • Anonymous Jul 06, 2008
    Me too - blank display, but backlight is on.
  • loadedlen Jul 24, 2008
    Ditto. worked fine last night, then poof - lights are on, but nobody's home. And as well, the remote works fine. Or I should say it DID work fine until I followed Logitech's advice to update the firmware. The remote is now stuck in safe mode and cannot be detected by XP any more.
  • ophirab Dec 19, 2008
    =( worked fine....was awesome...now screen is blank....need to rely on memory to do anything.
  • tracyleblanc Dec 25, 2008
    Same problem just started happening to me. WTF?
  • Calvis Jan 04, 2009
    Another victim. The hell is up with this? Anybody find a solution? This is a ******* $80+ remote...
  • Anonymous Jan 19, 2009
    Count me in on the same problem. Can't seem to get an answer from the support team from Logitech.
  • naenae0816 Jan 24, 2009
    i have the same problem!
  • Anonymous Jan 31, 2009
    this seems to be common
  • Anonymous Feb 08, 2009
    I am having the same problem, my screen is blank but my remote still works
  • Anonymous Apr 02, 2009
    Same problem. I find if is take out and replace the batteries, sometimes the text will re-appear. Sometimes it take a several tries.
I had the same problem - my kid stuck it in her mouth and then the screen stopped working. I was finally able to fix it by doing the following:
1. I took the remote apart by
a. taking out the four screws under the battery cover.
b. then, I used a small slot screwdriver as a wedge and ran it up the length of the edge of the remote while prying the top and bottom apart.
2. Once i had it apart, I took a blow dryer to it to blow out any dust and get rid of any moisture
3. I put it back together and it was in Safe mode
4. I took out a battery, held down the #2 button, and put a battery back in and got the "Update Successful" message
5. To my surprise, the remote was fixed.
Posted on Mar 01, 2009
This is a known issue. Logitech didn't even blink when I submitted a warranty request (WAY outside of warranty) No "try new batteries" or "let's reset the remote and put in in safe mode" - just a straight "we'll send you a new one"
They blacklisted my old remote so that I didn't need to return it, and shipped a new one right to my door.
For that reason alone (nevermind the fact that I own a slew of other great Logitech stuff) I have become a lifetime customer of theirs. Gotta love a company that steps up to the plate when they know one of their products is causing grief.
Posted on Jan 25, 2009
Add one more to the "me too" mix...
Posted on Jun 30, 2008
    Problem Solver:
  • 19 Answers
Well, I finally put together what worked for me:
1) pull a battery.
2) hold the power button down when you replace the battery - this should FINALLY get 'sefe mode' to show up on the remote
3) update remote
You may need to keep the battery our of the remote for 1 hour or so.
You may need to do this multiple times.
You may need to press power - OK - 0 <zero> at the same time before you do this (This is only if all else fails and you are really desparate and want to try anything. Try it with the batteries in only, Try it with the batteries out and hold all three down while you plug in the USB cable).
I did these various steps multiple times and it finally worked. Try the 3 steps top down and then with each of the alternatives a couple of times for each alternative.
Use the 'Power' - 'OK' - '0' sequence as a VERY LAST resort - this really messes with the remote and may cause it to get worse and require you to do the steps many times before it finally works.
Logtech harmony 550 button will not work. Only get a welcome message on screen display.
Remove the battery and allow the voltage on the circuit to fade off. now reset the battery and see if the remote works. If there was any battery leak then the pcb can be damaged due to corrosion. please check this link for tips to repair:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Oct 15, 2011 | Logitech Harmony 550 Remote Control
MY REMOTE DISPLAY STAYS BLANK EVEN AFTER CHANGING THE BATTERYS WHAT SHOULD I DO NEXT(LOGITECH HARMONY 550)
My advice is to call Logitech. They may replace the remote or give you a discount on a new remote. The LCD screens on these remotes have been known to fail, and it's a hardware issue so there is not really much you can do to fix it.
Aug 12, 2011 | Logitech Harmony 550 Remote Control
I have the Harmony 550 remote and it only displays the 'welcome to your remote' message on the screen. I have followed the advice of other posts to take out the batteries and massage all of the...
Hi.
Perhaps you do not already have the Harmony software installed on your PC?
If not, it's on the CD and you will need the USB cable to connect the remote to PC, but that comes much later after you have constructed a configuration on your Logitec account. Then the 550 should certainly be able to show more than just the welcome message.
You don't really need the CD because you might as well download the latest software version from the Logitec website for 550, install it on PC, and get the full instructions there.
Next register using the software on PC and check that you have the the latest firmware according to the instruction manual. The on-screen guide on PC will lead you through making a configuration for your devices.
Regards
Chas
May 15, 2011 | Logitech Harmony 550 Remote Control
Device freeze how to I reboot/unfreeze Harmony 550
Hey, try doing the following:
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
That fixed my 550 a couple of times. Seems that a firmware update will cure most ailments.
Hope it helps.
Apr 03, 2010 | Logitech Harmony 550 Remote Control
My harmony 550 displays safe mode . how do i fix it?
Hi . Here's how to fix it and get your remote out of safe mode:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help
Feb 03, 2010 | Logitech Harmony 550 Remote Control
Blank screen but backlite is on
Had the same exact problem. Blue screen, no text, but remote worked ok - if you could figure out which buttons did what. Tried every solution posted online - battery pull for 10 sec, battery pull for 1 hr, and battery pull overnight. Tried updating software, firmware, but nothing worked. Found a replacement screen on ebay for $26 shipped, replaced it in less than 5 minutes, and works great.
Feb 02, 2010 | Logitech Harmony 890 LCD Remote Control
Screen display not activated, no display except light background
HI! Here's what to do if your Logitech Harmony remote's LCD screen has gone blank.
If the screen is still blank after you complete these steps, then it is a hardware issue and you should contact Logitech's wonderful support team, given that the remote is still under warranty.
Dec 20, 2009 | Logitech Harmony 525 LCD Remote Control
Display on Harmony 520 not working but buttons are all working
Aug 07, 2009 | Logitech Harmony 520 LCD Remote Control
Ewaynuworld: Remote works but blue screen does not show anything anymore. Right now I'm able to use remote because I remember the buttons (no words show at all).
Aug 03, 2009 | Logitech Harmony 550 Remote Control
Logitech Harmony 550 Remote Control Logo
2,738 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
