Question about Pioneer DEH-P440 CD Player
Equalizer I hav a alpine 3318 equalizer that was working when i removed it from another car but now when i hook the rcas up it should turn on right? how come it doesnt? im pretty sure the rcas are its power sorce but correct me if im wrong. thanx
  • Kenneth Behrman
    Kenneth Behrman Apr 25, 2008
    is the din plug the line in? all the equalizer has is a dimmer, remote cable, line in (but there was no connector when i remvoed it from the car) line out front, line out rear, and sub out, thats it do i need the line in cable if i use the rcas? there are no other possible solutions i can think of should i splice into the line in? or cut of a line out cause the line in is a female connector and all the rest are male.
Need help? I have on of these that work fine for me
Posted on May 02, 2008
  • pdlnwhl May 02, 2008
    only needs one power to blue and there are two wires to connect in the din plug.
The alpine unit needs power at 3 locations. It gets constant and ignition thru a din plug and the blue accessory wire
Posted on Apr 22, 2008
I hav a alpine cda-w925ehi head unit an it just stopped an now says "interrupt"
Hi I believe you have an Australia model? Alpine's use what's know as an interrupt wire to hook into vehicles/phones to interrupt the audio of the deck when their is a signal sent to it. On the Alpine harness you need to search for the Pink/black striped wire which is the audio interrupt wire. Make sure that wire is insulated and not grounding out against anything or hooked up incorrectly.
-Boz
Nov 28, 2012 | Car Audio & Video
I have a kenwood excelon (794, I believe) with 6 pre-amp outs. I'm currently running a boston acoustics gt2-125 amp powering 1 alpine swr-t12 shallow mount, type-r sub (12"). I have 2 alpine...
This answer will require a very detailed technical solution, therefore I recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
Apr 24, 2017 | Clarion EQS746 Equalizer - 7-Band In-Dash...
I have my ipod hooked up to the rca's in the back of the radio but there is very little volume. nothing i do seems to help. i have the aux on but still barely any sound comes out. am i doing something...
Hi, the RCAs in the back are usually outputs, not inputs. The specs on this unit indicate that AUX input is optional. Are the jacks you're using marked AUX input? If yes, what kind of cable are you using to adapt the iPod to the RCAs? If no, you may need to buy an adapter. There is one here: http://www.crutchfield.com/p_500KCA420I/Alpine-KCA-420i.html?search=kca-420i&tp=120
I got this link from the spec sheet here: http://www.crutchfield.com/p_500CDA9851/Alpine-CDA-9851.html?tp=5684
Please let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Alpine CDA-9851 CD Player
Alpine CDA-9851 CD player
i/c on or off. set it too off
Jun 28, 2009 | Alpine CDA-9851 CD Player
Alpine equalizer wont work
to have them work you have to connect the yellow wire to constant 12 volt power,and the red to blue and white wire coming from the radio if you dont have a blue remote wire on the radio connect it to the accessory of the car wire that power the radio
Nov 04, 2008 | Alpine ERE-G180 11-Band Car Equalizer
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Pioneer DEH-P440 CD Player Logo
143 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
