Question about Panasonic (ET-LA995) Projector Lamp for PT-D995
Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
How do I install a replacement lamp Panasonic PT-60DL54J? I understand that I don't have to purchase another complete assembly, I can just replace the lamp.
Thanks.
Mac
This is a link to AVS for Panny PT-50LC (LCD) which I assume must be the same for the DLP.
With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds. The TV will be turned on and it will have a screen of status data atop an active TV channel. To get out of this mode TURN OFF your TV.
This initial "SERVICE MODE 1/3" screen shows -
LAMP OPERATION TIME
TOTAL :
CURRENT LAMP:
OSD DISPLAY :
LON COUNT :
Posted on May 12, 2008
Do you have pictured instructions and do you have to take off the entire rear cover of the tv. i have a 50 inch..
Posted on Apr 25, 2008
  • pineboy Apr 25, 2008
    also how do you reset the replace lamp timer????
  • 563 Answers
Hi Mac
Yes you can just take out the old lamp and install the new one in your existing lamp bracket. Simply unscrew , replace and screw back in.
Posted on Apr 16, 2008
How to reset lamp timer panasonic pt-50dl54 ty-la2004
Consult the owner manual or call Panasonic customer service for the method for this model.
If I see one I do not know, I also will Google the model number with "reset lamp timer" etc. if the Panasonic line is busy.
Dec 19, 2012 | Panasonic PT-50DL54 50" Rear Projection...
How do I replace the lamp and housing unit on my panasonic PT-52LCX66
You need a TY-LA1001 lamp assembly. Our Panasonic TV Lamp and Bulb Installation Guide shows how to change the lamp and has links to Panasonic Users Manuals.
easyab@hotmail.com
Feb 11, 2011 | Panasonic PT-52LCX66 Projection Television
Where do I purchase and how do I replace a picture lamp for a panasonic PT-56DLX75 56 in. HDTV Television ? I live near Sioux Falls, South Dakota.
Hi there this online store has the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=PT-56DLX75
this link has your TV manual and check page 67 it will show you were the lamp is located in your TV
http://service.us.panasonic.com/OPERMANPDF/PT56DLX25.PDF
this link shows you how to replace the lamp
http://www.fixyourdlp.com/guides/panasonic/TY-LA2005.php
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 11, 2010 | Panasonic PT-56DLX75 56" HDTV
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
JUST REPLACED MY LAMP TY-LA2004 HOW DO I RESET THE TIMER
hello
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
  • regards
    shaun
    Feb 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    Need instructions for lamp unit part number TY-LA2004
    the projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
    to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
    Jan 28, 2009 | Office Equipment & Supplies
    Panasonic PT-40LC12
    hi...
    Panasonic lamp timer reset procedure
    1. Press the power button to turn the unit on.
    2. There are 3 choices for this step, depending on the housing part number:
    A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
    B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
    C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
    3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
    OR
    3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
    When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
    Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
    Panasonic PT-50LC13 Television Lamp Replacement
    not really, just be careful about getting finger prints on the lamp as the oils from your fingers will shorten the lifespan of the lamp.
    Mar 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    867 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
