Question about Panasonic Lumix DMC-TZ3 Digital Camera
Won't turn on
I've had this camera since July '07. It's worked perfectly until last week. It just all of a sudden won't turn on. I've recharged both batteries - neither are powering it up. Is there a reset button or something?
    Novelist:
  • 172 Answers
You can remove the battery for more than 10 seconds to reset camera. If you bought it July 07, then it should be warranteed till July 08, even if you did not send in warranty card. Give Panasonic Repair Center the serial number and they can tell you if it is still under warranty.
If not, you can get estimate to fix it at local or internet or Panasonic repair centers. It is worth about $40 on ebay as is. If you have all accessories and box, up that to $80, $100 with two batteries.
Posted on Apr 13, 2008
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
I bought my camera in july 2006 - recently it runs
I´ve got the same issue. If you use the batteries that were in A540 in another camera, does it still work?
Jan 11, 2010 | Canon PowerShot A540 Digital Camera
Toshiba Camileo h20 battery problem Toshiba Camileo H20 camcorder bought in July O9 Worked fine on 2 week holiday and have recharged the battery 2 or 3 times since. Latterly battery charge didn't last very...
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
Mar 27, 2017 | Toshiba Video Cameras
For some 9 months the camera worked fine, then the battery time went down to two weeks, and now is down to one day. What is causing this sudden drain of the batteries?
You might need a new battery. Many digital cameras put a lot of strain on the rechargeable batteries so the y don't last long. Best ones I've found have been Rayovac lithiums or Hybrids.
Aug 21, 2009 | Cameras
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
Beeping
no problem. your rechargable is not strong enough for this camera. i use rayovac rechargeable from wal-mart and the batteries have to charge for two full days and make sure the light on the charger is off before removing the batteries from the charger. then put them in the camera and it will work perfectly. your batteries aren't strong enough for the camera. go out and get some energizers made just for digitals. they last forever but, they'll do until you get your rayovac rechargeable recharged. and coming right out of the pack they are not charged give it 48 hours and they'll last weeks.
Sep 18, 2008 | Samsung Digimax D53 Digital Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Losing power rapidly...
The only thing I can suggest is that the metal connections on your camera have corroded due to the long life of your camera. I had a similar problem where any batteries I used would not work, regardless of what kind of battery it was. Turns out I had a nice greenish layer of corrosion on my connections which I sand-papered off. This might be a little tricky if your connectors are way inside of a battery holder, but it can be done nonetheless. Try taping some sandpaper to the flat end of a pencil and clean it out that way. Hope it works.
Jun 25, 2007 | Canon PowerShot S1 IS Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
254 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
