Question about Casio Exilim Card EX-S600 Digital Camera
Does not turn on
The LCD lights up around the corners but thats all that appears on the screen. Also once on it sporadically allows to zoom and even take pictures.
  • ERIFFAS May 06, 2008
    MI CAMARA WHEN I TURN IT ON THE LCD JUST TURNS BLANK ONLY LIGHT NOTHING ELSE
  • 374 Answers
I would say that if you can take pictures it is just the lcd that is out on your camera. If it is not allowing you to take pictures all the time then there maybe a lens error. You can send it into repairs and they will tell you what it would cost to fix it.
Posted on Sep 12, 2008
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
My screen appears to be 'zoomed in' note that this is not a resolution issue nor is it just a web browser page that i have zoomed in on using the mouse wheel. My screen was zoomed when the log in screen...
This sounds as if you have the magnifier on if you are using Windows. What the magnifier does is just what you are describing. It zooms in on part of the screen and lets you pan around the screen when you move the mouse to the edge. Unfortunately, I do not know which version you have. If you have XP, you can view this webpage for specific instructions: http://www.microsoft.com/windowsxp/using/accessibility/magnifierturnon.mspx.
If you have another version, to change it, click on Start Menu>Programs>Accessories>Ease of Access. It should be found there. Once you open it, you should be able to turn it off and go back a normal screen.
I hope this solves your problem. Let me know if it does not.
Apr 02, 2011 | Computers & Internet
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
How do i get video to workon my vivitar vivicam x327
Video Mode
Press the MODE button to select the Video mode.
Note: The camera has limited internal memory allowing you to record up to 20 seconds in QVGA. An SD
card (up to 8GB) needs to be inserted in order to use the video mode normally.
When the icon appears on the top left corner of the LCD screen this indicates that you are in Video
mode.
1. Prepare the object or subject you wish to record.
2. Press the Shutter button to begin shooting the video.
3. The elapse time will appear on the top right of the LCD screen and the icon will flash on the
LCD screen.
4. Press the Shutter button again to stop the recording and save this file in AVI format.
Note:
1. You can preview the AVI files in Playback mode or once downloaded to your computer by using
Quick Time and Windows Media Player.
2. When the camera's memory is full, the “Memory Full Insert a SD Memory Card to Transfer and
Shoot More video!” message will appear on the LCD screen when you attempt shoot more videos.
Download the test file from the internal memory to the PC or delete them to shoot more videos.
27
Alternatively, you can insert a SD memory card to expand the memory to record longer videos.
3. The LED will light up when the light condition is not good.
Feb 22, 2010 | Vivitar ViviCam X327 Digital Camera
White spots in corners
"It's referred to as 'flashlighting'. It's a common problem in LCD/led as the driving factor is lighting pushed through pixels to create the picture. What you are seeing is a spot where the lighting is passing through unscathed or overpowering around the edges since this is an edge lit tv.
Some TVs are worse than others even if they are the same model, size and even batch.
This can be caused by many reasons... You have 2 options, return and/or exchange it at your local store if still in that window. Or you can call the tv manufacturer to see if it is out of their allowable tolerance levels.
Remember some flashlighting is still within their specs so even though you may not be happy with it the manufacturer may not fix it.
Many people find some relief by turning brightness down, contrast down and some TVs allow you to adjust back light levels. If this one does then make sure it is not on high.
For more info on this I would go to hidefjunkies.com as it has tons of great info."...Also,"take it off Dynamic mode is the first step. Then put it on something like Standard or Movie. This will not fix it permanently, but will give you a better experience." (I hope this answers your question...if it was ME,I would take th darn thing back,if still within warranty period.)
May 09, 2017 | Vizio L37 Television
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
Aug 03, 2008 | Archos 605 WiFi Digital Media Player
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Blue splotch appeared in lower right corner of the screen
I had a 52" Zenithe LCD with the same problems that you are discribing and since I work in the industry I have a relationship with a couple of authorized service centers. I took a digital picture and emailed it to both of them and both replies were that the light engine was going out and it would be cheaper to buy a new one than to fix this one. That is the bad news, here is the good news. LG/Zenith has lost a class action lawsuit regarding the light engines in the LCD rear projection TVs. The settelement includes extending the manufacturers warranty till 2010 and/or repayment of money paid to fix, calibrate or replace the TV.
Jan 13, 2007 | Zenith D52WLCD 52" Rear Projection...
Does any sign appear on the LCD screen to indicate that the optical zoom has changed to the digital zoom?
Yes. The digital zoom is indicated by displaying 1.2x to 4.0x in yellow at the upper right corner of the LCD.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Casio Exilim Card EX-S600 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
