Question about Canon DC210 DVD Camcorder
IFO files - cant copy to PC
I spent every last dime on this lil rig, and now i can copy files over to my pc for editing. dont remember which mode i was in (video vr) but nothing seems to work. I cant find a free program to convert to a more common file format, and if i do, it is only trial then buy. any suggestions?
    Problem Solver:
  • 5 Answers
Ive had this same problem since Xmas, and then I decided to look into it, I just got this program called iSofter VOB Converter like 2 minutes ago, and I can edit videos on Windows Movie Maker, and you get to chose what you want to convert it to... hope this helped
Posted on Jun 04, 2008
Advent will not BOOT
The BOOT.INI file may be corrupt. Boot to a command prompt and rename original file c:\ren boot.ini boot.tmp. Now type edit. and insert the following script.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save as boot.ini. Alt key gives you the menu options
You can also create the file elsewhere and copy to c:\ Remember to rename original.
Note! This is a single partition standard from factory configuration.
Oct 25, 2012 | Computers & Internet
Tip
How to get 100% success DVD-Video Recovery with IsoBuster Pro
So the deal is you have a DVD-Video that you created and you want to make a backup copy OR your DVD Player skips on playback due to a surface defect or deep scratch, you have already tried to clean and repair it and still it wont work, check out my tip on how best to do this HERE
The quickest method is to create an ISO image using one of the top applications like ImageBurn or CloneDVD or DVDShrink the thing is al three fail on CRC or read errors on either the IFO BUP or VOB files so what can you do?
Using ImageBurn my personal favourite and selecting the VSO Patin Couffin Driver with a low read speed of x2.4 from the I/O settings interface and the default settings it will cope similar to Alcohol 52% FE and create the ISO upto the point where the first bad sector is then try to finish the ISO, it also tells you how many sectors are being scanned and the number of bytes in real time;
Using DVD Shrink pulls an immediate Cyclic Redundancy Error on the D: drive where the DVD-Video is inserted
CloneDVD pulls on IFO read error on VTS_04_0.IFO as this is a major requirement for successful DVD navigation it contains important navigational information, such as where a video chapter begins, and where audio and subtitle streams exist within the movie (VOB) file.
IFO files are not encrypted but without it this software can't correctly re-author a new DVD video using this method, the BUP file in VTS_03_0 is not a problem as it is just a backup of the IFO and this file is fine in this case, so only this one error is thrown up.
Alcohol 52% FE will attempt to create it native MDS image file format and as lon as you check skip read errors and or use data precision management then it might work the main benefit is it will log each sector error and create a graph to show where the errors are in relation to the total number of sectors.
AnyDVD will rip any DVD, go figure, whether it be CSS or NOT if there is an IFO issue it will throw this error, not much help to us with a damaged DVD there then
SO WHAT CAN YOU DO THEN READ ON !!!
IsoBuster v2.7.0.0 is to the rescue, in the Professional mode you can extract the VIDEO_TS folder from the File menu it will scan the DVD for errors and then give you a list of the files that have Unreadable Sectors, you don't need the AUDIO_TS folder unless you will be using older standalone DVD players to view the result, its also in v2.8 Beta HERE on Filehippo it costs $29.95 (£20) an well worth the money.
If you select insert Dummy and Apply always on the first sector that has problems then it will do this in this case at 42% for all subsequent bad sectors through the 100% complete 21 file extraction.
NOTE: This may take upto 4 hours depending upon the number of bad sectors within the files until finally it finishes with a full list of recovered files in this case original scan found 2 files a BUP and an IFO from different VOBs
The final result shows 2 extra VOB read errors withing the two VideoTitleSets (VTS) linked to the IFO and BUP files, into which IsoBuster has added dummy sectors to make complete files that will now play.
If you wish to then check the extracted files within the VIDEO_TS folder then use DVD Shrink it will scan all files very fast and you will see that the read errors are now GONE !!
SPECIAL NOTE:
In this scan and extraction there is a complete BUP (IFO BackUP) file for VTS_04_0.IFO as the BUP is an exact copy of the IFO and is good then just copy this good BUP and rename it as the IFO in place of the recovered IFO this will improve you playback for that Video Title Set.
The opposite can be one for VTS_03_0.IFO that had an unreadable BUP file just create a new BUP from the good IFO, this will help if the IFO ever becomes unreadable on the new DVD that you want to create.
You can apply this method to CSS encrypted DVD content using Slysoft's AnyDVD, but only if you own a licensed copy of the original to recover information from a badly scratched DVD-Video
on May 12, 2010 | Microsoft Windows XP Professional
Can not play vod file on computer
I assume you mean VOB. I have not heard of a VOD file...
If you have gotten your hands on a VOB file somehow, chances are they have been copied/extracted from a DVD. VOB stands for DVD Video Object and is the core file of a DVD containing the actual movie data, an MPEG movie stream and the supported audio.
To play the VOB files, you need to have a DVD player that supports VOB format. However, if you have the Windows Media Player (version 12 or higher) or VLC Media Player, it is good enough to play the file. Note that you will see a prompt telling you that it is an unsupported format, don't worry about it and just play it anyways. It will play just fine.
If you want to obtain the VOB file from a DVD for some reason, just open the DVD in Windows Explorer instead of playing it through a media player. The VOB file would most likely be under the VIDEO_TS folder. Some other files that you will also see in the folder are IFO and BUP. The IFO files are the information files containing meta data about the DVD and instructions for the DVD player on how to handle the disc. The BUP file is simply a backup copy of IFO files.
If you want to convert VOB file to AVI or a similar format, aviNET is a great tool to do that
Dec 01, 2010 | HP Computers & Internet
Does i copy dvds2 standard edition run on windows 7
Yes if not native, then in compatibility mode. Right click .exe file > click properties > select Compatibility tab and checkmark "Run this program in compatibility mode for" and select a earlier Windows Operating system, and click apply
May 19, 2010 | RTO Me Too Software ICOPYDVDs2 Standard...
Ok. I used VHS/DVD machine to transfer VHS home movies to a DVD. I now need to take small pieces of this video and convert them to AVI. (My objective is to upload short video clips to a digital picture...
you can use a programe called avi converter 9.0 i cant remember weather you need a key for it but i have a key 4 avi conter 9.0, if you give a email on chrisy3000@hotmail.com ill send you the key, but i just dont want to send it here, i rather send it privatly, cheers
Dec 12, 2009 | Computers & Internet
What can do to view and edit my GZ-HD6 camcorder on my PC (Vista)
Change the file extension from .MOD to .mpg and then double click it to play it. I use Cyberlink Video Director to edit my files which is the software that came with my camera
Mar 20, 2009 | JVC Video Cameras
Missing normalize.dll
Use a memory stick to back up all your programs you have installed and then format you computet.
or download or buy a new program for Explorer or get Firefox it is a much better and you can download it for free. Remember to create back up files on an old laptop or a memory stick just in case of any loses during formating the computer... The same is advisable is creating an new account.
Sep 25, 2008 | Microsoft Windows XP Media Center Edition...
Hi I cant turn on my computer its Windoes XP home edition and never happened before when I press the switch buttom theres a noice 3 x beep and thats it then nothing happens once appeader a option to resume...
If you can't get into safe mode by pressing F9 during start-up you may have to reload windows. If you can get into safe mode, back-up data and reset the PC to the last configuration on which it worked. When you see the "Please select the operating system to start" message, press the F8 key.When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
Aug 20, 2008 | Computers & Internet
Transfer from my canon dc210 to my pc
If you can play the DVD disc on your computer you will be able to transfer footage and edit it.
Put the DVD disc into your PC's DVD drive, then
1. Select 'start'
2.
Select 'My Computer'
3.
Find your PC's DVD drive in the display of devices shown, right click on it, then left click on 'Explore' in the drop down list.
4. Copy all the files you see shown with the 'Explore' option to a folder on your hard drive.
You can now use the software you normally use to edit the files you've just transfered to your hard drive.
Mar 19, 2008 | Canon DC210 DVD Camcorder
Canon DC210 DVD Camcorder Logo
48 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
