Question about Kenwood Excelon DDX-7015 Car DVD Player
No sound dvd cd play but no sound only sound a get is from thr tunner
  • afebus1 Apr 12, 2008
    all the wires are good radio come on dvd play but do not sound and i`m using rca for tha speakers when i press src the only thing tha sound is the tunner while the dvd is showing
    i got thr radio from my brther 1s car and it was working fine in his car three days ago
    Brigadier General:
  • 6,966 Answers
Hi afebus1and the the indulgence of eagle338...
Have you tried the reset button?
Posted on Apr 15, 2008
  • 4,889 Answers
Make sure the wiring is proper.. Are all you wiring a brand new player into your car? If yes here's the wiring procedure..
all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Yellow is your constant wire
Red is your accessory wire
Bllack is ground after that there will be a orange wir e that is optional hook up to run the sterio with the dash dimmer 2-3 blue wires which you can use for AMP remote wire or elctronic Antena
then there are the White and white with black stripe
Green and green with black strip
Purple " "
Grey " "
are your 2 front and 2 rear speakers
which go where i always for get but when your installing the sterio you can set the sterio to run frount let and then hook the wiers for that speaker up when you fin the right one
Posted on Apr 12, 2008
  • 2 more comments
  • eagle338
    eagle338 Apr 12, 2008
    If you are sure that the wiring is proper then it sounds like a circuit board bug.If its a new player then please run to the store and ask for a replacement..
  • eagle338
    Ok.. The tuner sound while playin DVDs means that you have interchanged DVD audio output wire with the radio.. Please correct this wiring error. May be your brother may help you set it up.. trust me its a wiring fault..
  • eagle338
    Please check the ground too..
  • eagle338
    eagle338 Apr 16, 2008
    Did you figure it out?
The sound from my tv will not play through my surround sound.
Make sure that you have your receivers input selector to the correct input that you plugged your tv into. Try plugging the tv output into the working input that you have for the dvd. If the tv still does not work, and you are using a working input, then clearly, there is no workable signal going into the receiver. In tv menu check the audio output format.
Some tv sets output their audio signal in digital format. If you plug that into a receiver with an analog audio input it will result in silence.
Apr 02, 2014 | Audio Players & Recorders
Even when i play a cd or dvd i have played before i still cant get any sound
Do you have the Volume Control icon next to the clock (lower right corner of the screen)?
Mar 09, 2014 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd audio
remove it from device manager and see whethrer there are any resource conflicts
May 24, 2010 | Creative Labs Sound Blaster Live! 5.1...
Myproblem is that thr cd drive refuse to play some dvd disc. its shows that there is no disc or it will not respond at all. the version of my powerdvd xp 4.0
It may be hardware problem or software problem. If lense is covered with some dust particle then it some time plays or can not play. so you can easily buy cd drive cleaner as liquid cleaner.
Also some codec may be missing . Install all the codec of video and also try to use cyberlink power dvd latest version. You can easily download from http://rapidlibrary.com
Nov 04, 2009 | CyberLink PowerDVD XP Standard 4.0 Upgrade...
Cant get sounds when playing a cd,but i do get sound when i have it on tunner
That's because the amp is connected to the power antenna output of the radio. It should be connected to the normally blue white wire from the radio. If none present use the ignition wire normally red to turn on the amp.
Jun 30, 2008 | Kenwood Car Audio & Video
VSX-D711
Yes.
There's an integrated circuit that steers all the input signals thru.
That has crapped out.
Jan 28, 2008 | Pioneer VSX-D711 Receiver
Unable to burn cd or dvd
on the end cable connector should be master on middle connector should be slave or both on CS cable select.
Nov 02, 2007 | HP dvd740i DVD±RW Dual Layer Burner
System unresponsive when modes are switched
Sounds like there may be a glitch in the microprocesor. Make sure when you unplug it that you leave it along for a few days and is there any type of clock or standby batterys in it take them out as well. If that dosent correct the problem your gonna need a service manual to trace the switch pulse to see if the units Switch matrix lines are low or lost because of a faulty micro or a bad componet like a small caps they install on the matrix to keep noise off them. Hard one to call with out seeing unit and analizing unit Good Luck
Apr 12, 2006 | JVC TH-A30 System
Kenwood Excelon DDX-7015 Car DVD Player Logo
90 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
