Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Upgrade to a new motherboard?
If I install a new motherboard that costs about $80, will I be able to use the windows XP software that came with my emachine? O r do I have to also buy a windows XP home edition CD and install it? I have tried just about everything to this computer, unhooking peripherals, making a boot disk, trying my recovery disc CD, bought a new power supply, new CPU celeron 2.3, nothing makes it work so fwr. The monitor works with another computer, but no pic on the emachine computer. The emachine t2385 just lights the power on light, that's all.
If the problem is in the motherboard, where do I go from here?
Thanks in advance!.....................clint
  • 1 more comment
  • GadgetJunk1 Apr 12, 2008
    Yes, I did install another power supply, as I said. Still the same thing, power light stays on, nothing on monitor. No 'beeps', etc. No 'blinking' power light. I do have the original CD that came with the computer that says recovery on it.
    Originally, the CPU was plugged with dirt and debris in the heat sink. I cleaned it out and bought another 2.3 celeron cpu and installed it. Nothing! Installed a 300 watt power supply, still nothing, just the cooling fan ran faster.
    I discussed at a computer shop about it, they think problem is in the motherboard. They showed me an 'upgrade' motherboard that uses the same celeron cpu, but needs different memory stick and also said I would have to get a copy of windows XP. The cost is nearing the act of replacement of the computer. Trying to decide. A new tower only, at Walmart, is about $300. If I end up that way, I might just add my Hard Drive to it, if it works okay. I save all my work this way, that is on the HD! I'm just rying to find out wether I can fix this computer or not.
  • levieux Jan 04, 2009
    The same problem as all the others just a green led inside lit and nothing else works changed mother board ,power supply from frpm emachine co. with new flat wires and addapter for hd and still the same does not start but if use the tester for ps it works and the fan works also
    I noticed that one led seems to be burnt with my ohm meter for them diode test and I have read that if that is not working that could be the problem
    My model is D2823
Nothing happens at all except these:
1: The cooling fans come on in the correct manner.
2: The "Power Light" comes on and just stays lit. No blinking!
3: The CD Drive at the top does open and close, do not know if it reads anything or not.
That is all, not anything else happens! I has an imperial motherboard #20021218 with a 2.3 celeron cpu. What is a good swap for the motherboard? Is this motherboard possibly fixed? I don't see any "leaking' capacitors or any burnt spots on the board. Thanks!
Posted on Apr 16, 2008
  • 236 Answers
I think there may be another issue.. It could be the power supply.. Have you tried a new one?
Have you installed any additional ram lately?
You can use the old XP software with a new motherboard, but it can be a pain in the **** to set-up if it is the OEM version of Windows, or a Recovery Disk that came with your machine..
What you could do, if you bought another motherboard, find someone with a Genuine Windows XP disk, and use your Product Key to install it..
Posted on Apr 12, 2008
  • 3 more comments
  • Dave MacPhee
    Dave MacPhee Apr 12, 2008
    it is hard to tell what is going on.. Have you checked the mobo to see if it is fried? Also, the fans come on, and the light comes on, but no beeps? Could be a number of things..
    I would guess that you have checked all the connections from the power supply to the drivers/board, and made sure that all connections to the board/hdd are secure. Also, make sure that the RAM is seated correctly, I know that you would usually get a Beep on a RAM error, but who knows? Stanger things have happened.... Also, check the connections to the power/reset buttons (as if some are backwards, this could occur)...
  • Dave MacPhee
    Dave MacPhee Apr 16, 2008
    Didn't see this posted, but are the harddrives spinning?
  • Dave MacPhee
    Dave MacPhee Apr 19, 2008
    Sounds like the HDD is not connected properly.
    Please check the internal connections to the HardDrive (power and IDE cable).. Make sure the IDE cable is plugged into the Primary (or IDE 1) channel on the motherboard. Also make sure that the harddrive is set to master on the back of the HDD (jumper settings).. If you CD-ROM is connected to the same cable as the Harddrive, make sure CD is set to SLAVE and HDD is set to MASTER.
  • Dave MacPhee
    Also, make sure that the power supply is set to the correct voltage (usually 125 and not 220)
  • Dave MacPhee
    as for swapping the motherboard, it is a Micro ATX board, and is pretty much outdated.. Your better off buying a new Motherboard, better processor and a case. (good ones will total around $250 all together)...
    If you wanted a motherboard that matches the one you have, you need a socket 478, and that mobo will run you around $150 bucks on it's own.. Unless you can find one on Ebay, or at a second hand/refurbished store.
Copy WIndows XP from one hard drive to another
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
Jul 20, 2010 | Microsoft Windows XP Professional for PC
How can I upgrade a windows 2000 system?
with a new os like windows xp or windows 7
May 06, 2010 | Microsoft Windows XP Home Edition
I don´t get any harddrive acceped in the installation during installing Windows XP after monting an new harddroive, I have formated the drive before monting it!
Is the XP an Upgrade or Full install disk? - the upgrade will NOT install unless there is a 'qualifying' OS there first. Onl the Full version will install onto a blank HD.
Feb 05, 2010 | Packard Bell (181368) Motherboard
Upgrading my old laptop
this are the things that will help you upgrade your laptop. first of all replace the ram memory with a higher configuration.then get your hard disk reformat by reinstalling fresh operating system like windows xp-sp2 or windows vista.install all the latest updates and drivers and its done. please do not forget to rate the solution.
Jun 12, 2009 | Dell Inspiron 2200 Notebook
Hi guys, I'm new in this forum and I really need some help. I have a p4vmm2 motherboard with Intel Celeron 2.0 Ghz CPU and I want to upgrade it with Intel Pentium 2.4 CPU motherboard. I have already tried...
Whenever you try to upgrade motherboard and CPU's with Windows XP, you're probably going to have to format your drive and re-install XP. When you originally install XP it detects the motherboard and IDE controlers for your hard drives and installs the drivers needed but it doesn't install all drivers for motherborads and IDE controlers. When you swap out motherboards and the system tries to fire it doesn't have drivers available for the new motherboard and can't complete the boot into windows. Every once in a while you get luck and the new and old motherboard can use the same drivers but this is very rare. So when upgrading motherboards plan on backing up your hard drive of all files you need to keep and being prepared to format and re-install windows.
May 15, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
Winxp instalation
hi,
There is not way to install a windows xp os without SATA drivers. If you don't want to use the floppy disk to make the os recognize the HDD, you can integrate the drivers in the Windows Xp installation Cd, using software like Nlite.
Another solution is to use a IDE HDD, the old kind with the 80 wire ribbon cable.
Mar 31, 2009 | VIA ASUS A7V600X MB AMD KT600/ 400FSB/...
Sftware
Hi, Unfortunately any of Bernina's software that is older than Version 5 , will not work with Vista. There are some software patches available on the berninausa.com web site, but there is nothing out there that will help you if you have any Version 4 software or older. Microsoft really through out a curve ball to everyone with VISTA as there is a lot of software out there that will not work in that operating system.
Actually the lowest cost solution would be to get a nice used computer that runs Windows XP. You do not need a super fast, state of the art computer to run embroidery programs.
I bought a nice used computer at a yard sale for $10.00 and it even came with the XP install disk. I replaced the hard drive just because they do wear out after a few years, installed XP in it and that computer is now in my wife's sewing room and it is only used for her embroidery work.
You might have a computer repair shop in your area where you can buy an older XP computer that has been reconditioned. The few dollars you would spend to get an older computer would cost you far less than buying new Bernina Version 5 software. It is EXPENSIVE! Good luck...bushvideo
Sep 11, 2008 | Bernina Artista 180
Printer problem
here is the link for the driver download for the i250 for xp (hope you didn't mean you threw the printer itself away) http://software.canon-europe.com/software/0023758.asp?model= Here is the link for the bjc 80 scanning driver for xp; http://software.canon-europe.com/software/0018984_0000424.asp?model= but unfortunately canon does not seem to have a driver for printing in xp for the bjc80, it doesn't seem to be compatible - contact canon and they might have plans to release an xp driver this link has dos drivers for the bcj80; http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 Hope this helps - other option would be to go back to windows me/2000 or get an xp capable printer - if you get a new one make sure it can deal with windows vista as well in case you upgrade in the future :)
Mar 18, 2007 | Canon BJC 80 InkJet Printer
Motherboard upgrade
The different hardware components on the new motherboard require different drivers that what are already loaded on your installation of Windows. My guess is something requires a driver that the base Windows driver install will not cover and as a result errors out and restarts. I too have tried this trick on several occasions, sometimes it work and sometimes it doesn?t; however, the key is similar hardware. My guess would be IDE controller, video, chipset or perhaps USB 2.0 is causing your problem. What you can do perhaps is boot into Windows safe mode and try to figure out what is causing the problem. In the long run it may save time and aggravation by just reinstalling Windows ?? Let us know how it turns out.
Jan 02, 2007 | MSI RX480 Neo2-F Motherboard
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
350 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
