Question about Asko W6021 Front Load Washer
Washing machine I have an Asko washing maching. At the moment there is a strange musty smell coming from the machine after a wash. Dont know what this could be. Any ideas?
I would suggest you also consider your detergent. I had this probelm and looked it up on line and discovered that liquid detergents can accumulate a gundge in the drum etc. and that it is best to use powder - I switched and have not had a problem since.
When you first switch allow the wahser to go through a couple of hot cycles with no clothes (I think I may have also used baking soda in one of these cleansing washes.....
g'luck
Posted on Apr 19, 2009
Open left hand lower panel & remove plug check nothing is caught in pump.If this is clean then then just do some washes occaisionaly water only. If your'e machine may
have not removed all excess water.
An easy check for this is remove top cover 3 screws at rear,will need saftey screw kit available cheap & you will see electrical drawing,you will notice a pressure sensor on drawing
it's really a vacuum switch black with red sticker on top.
Remove vacuum hose & blow slightly on vacuum unit untill you hear or feel diaphram close with power on. Pump will start operating if no water is removed its empty.You can either suck in
on vacuum unit to stop pump or simply switch off.
Posted on May 06, 2008
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
We have just moved into a house and the indesit washer dryer makes the clothes smell off. Have cleaned out the drawer, cleaned out the seal around the door, put it on a hot wash with soda crystals, used a...
i knew someone that had that problem, and they said they ran vinegar through the washer. I dont know how true it was, but they said they never had the problem again.
Apr 29, 2012 | General Washing Machines
I have a whirlpool cabrio washing machine. I have a problem. Our clothes are coming out smelling musty and nasty. They dont start smelling until they are wet, like with sweat Or the towels when we dry off...
If you dont wash whites with clorine bleach, you may want to every once in a while. Clorine kills germs and backteria which can smell. washer pumps do not get 100% of the water out.
Sep 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
Musty smelling washing machine
www.smellywasher.com you can order here to take care of that problem!
Jan 17, 2010 | Whirlpool LSR5132PQ Top Load Washer
Clothes smell from Kenmore Front Loader
run 3 cups of bleach on high water setting with hot selected as water temp, repeat as ness to eleminate odor
Sep 11, 2009 | Washing Machines
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Clothes smell musty
Clean th filter in the front of tha machine. Than take an OLD towel and run a hot wash with chlorox.
After that you run it again with vinegar and that should relief your problem.
i have an LG too.
Jun 21, 2008 | LG WM-2077C Front Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Asko W6021 Front Load Washer Logo
250 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
