Question about GE GSL25JFPBS Side by Side Refrigerator
Freezer Fan Revving up and down / creating 'howling'
I have had my GE Side by Side (GSL25JFPHBS - AH244410) for just under 3 years. Tonight I heard a 'fan revving' and howling coming from the freezer side. I opened the door and observed that the fan just below the ice maker was revving up and down very quickly. I have saw on 'Fixya' that other models have had the same issue. I did call GE 'Answer Center' and she claimed she never heard of the problem. After the call, I went back down stairs and the fan was now on 'full speed' with no howling audible. I'm guessing since I had the doors open for so long trying to figure out the issue, it caused the temp to rise.
Is there any recalls or any other information that would keep me from spending $$ on a repair visit?
Thanks for your help!
  • cableguy1970 Apr 12, 2008
    HI Sai!
    I did inspect the fan, its clear and moving free. The only issue is like there is a gremlin in the back of the refrigerator with a speed switch making the fan go 'faster' then 'slower' then 'faster' then 'slower' in very rapid succession. On the 'faster side' its creating a 'howling' sound, then it goes away on the 'slower side' - its very annoying.
    I did inspect the fan, its clear and moving free. The only is like there is a gremlin in the back of the refrigerator with a speed switch making the fan go 'faster' then 'slower'; 'faster' then 'slower' in a very rapid succession. On the faster side its also creating a annoying 'howling' sound, this goes away at the 'lower' speed. Imagine this 'up and down' speeds with the howling - very aggravating!
    Sergeant:
    Champion:
  • 427 Answers
The piece or "brain" that controls the fan can sometimes become confused. If it gets clogged with debris, or starts to malfunction, it may have the fan behave in weird ways.
Posted on Apr 12, 2008
  • 4,889 Answers
Sometimes the fan gets clogged with debris and can make a lot of noise as a result. If this is the case then simply clean the blade with a soft bristled brush, you can usually get one of these brushes from a hardware store. If it doesn't need to be cleaned then the whole motor may need to be replaced.elps,
Hope this helps,
Sai.
Hotpoint HSS25GFP with a loud howling sound in freezer and no water dispensing
The howling sound usually comes from an electronic control when it's going bad. I've also heard of the noise coming from the special shaped condenser fan you have underneath around back. GE may have a fix for this.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Feb 14, 2010 | Hotpoint HSS25GFP Side by Side...
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
Mar 26, 2009 | GE Refrigerators
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Noisey ge side by side
hi thanks for the question that noise is the fan in the freezer.you replace the fan motor the water disp problem is the little switch inside the freezer door difficult to get at please accept with a positive feed back thanks the appliance doc
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Ge side by side freezer fan
Hi johnwayne751.
Your freezer fan bearings are toast, time for a new freezer fan.
Aug 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
It is very common for the fan inside the freezer to develop a loud noise as it runs. Its in an environment that is hard on them, cold, wet. Its a small and simple motor, and you are right in believing there will be more problem in the future, as the stator is probably touching the housing. It has a sleeve type bearing, and its probably worn a little causing the shaft to wobble. Eventually it will stop completely and the freezer will get warm.
Mar 07, 2008 | GE DSS25KGT Side by Side Refrigerator
Howling - Which is the correct fix
I think I have the same problem. The unit is also about 2 years old (GSH25KGRBB). I have an extended warranty. They already replaced the controller card. I see it is the exact part number you have mentioned. It seemed to help for awhile but I think it has gotten worse again. The noise is more consistent after they changed the board. Less revving up to "turbo" mode. Howling is a good description. I can hear it now, on the other side of the house. I would change the fan out. I think they did the board first because it probably is easier even if the part cost is higher. I will probably call them back again. This will be the third time. The first time they just changed the little flapper on the ice dispenser. Otherwise the unit cools and runs flawlessly.
Aug 11, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
667 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
