Question about NEC Refurbished RC-28C ALARM CARD HECI M3ACN83AA (R3860) Transceiver
2001 plymouth neon
My car alarm goes off for no reason. It seems to happen more when the weather gets warm. I'd like to just disarm it for now until I can get it fixed...
My car radio wont work but the radio lights stay on
Posted on Apr 26, 2008
How do you fix, condensation in your feul, 2001 plymouth neon
If you are sure its moisture you can purchase a solution that will take the moisture out of the fuel as long as there is not water sitting in your gas tank. If you are letting a vehicle set all winter and going to use it later you should fill the gas tank with gas before storing and this will prevent moisture from forming in the tank as the weather gets cold and warms up. Even in the winter with all vehicles you should keep your fuel tank above half full at all times. People sometimes feel it takes too much money to fill the tank but it takes the same amount of gas to put in the top half as it does the bottom half.
Apr 03, 2016 | 2001 Dodge Neon
I'm trying to locate the oil sending unit on a 2001 plymouth neon
How many miles on the car? I recommend hooking up a direct reading oil pressure guage. Oil level is not the only factor on oil pressure. As an engine ages, clearances and bearings wear and the pressure falls. Using too thin oil can result in low pressure.
Jan 02, 2015 | 2001 Plymouth Neon
2001 plymouth neon sputtering
If you have an automatic transmission, you may be experiencing torque converter clutch (TCC) lockup shudder. There is a solenoid in auto transmissions that engages a clutch in the torque converter to save gas on the highway. These frequently stick open and cause problems at stoplights. IF you have an auto, a pretty good way to check if this is the problem is to put the car in neutral at a stoplight (CAREFULLY) and see if the problem goes away. Also, the clutch should not engage until the vehicle is warmed up, so if your problem happens when your car is cold, this is probably not the issue. Sometimes, these solutions can be inexpensive. I fixed my own TCC solenoid on my 1993 Chevy for about $20. Other times it can get spendy.
Mar 16, 2013 | 2001 Dodge Neon
2001 dodge neon car alarm goes off with no reason
There is a reason and that is that one of the door ajar sensors is defective most likely. To determine which sensor is the problem you must have the dealer scan the system ans be able to duplicate the problem.
Jun 05, 2012 | 2001 Dodge Neon
Every time I open driver side door the alarm goes off but not the passenger side. I put key in ignition it stops. What can I do to stop it.
stop locking the door with the lock button while the door is open. That engages the factory alarm. You can also use the key in the driver door lock to disarm the system
Apr 23, 2011 | 2000 Plymouth Neon
My oil light comes on after it is warmed up for awhile.its a 20001 plymouth neon
sounds like a bad oil pump , I would not drive highway speed you could lock up motor.
Oct 09, 2009 | 2001 Plymouth Neon
Antitheft alarm on our 2001 mercury sable goes off on its own
Get a new car! JK - my 2002 Sable does the same thing. It can be 5 times a day then not for a month, or 2-3 times a day for a week straight. It happens in different locations and different weather and different times of the day. To my knowledge has never done it in my garage at home.
I have not called a dealer. Has anybody ever found the real problem? Could it be in the remote itself? I tried leaving it unlocked at work, but yesterday it went off just as I was reaching toward the door handle.
Aug 28, 2009 | 2001 Mercury Sable
Acura 1.6 el 2000 factory alarm goes wild when damp weather.
check with your local dealer, there where having issues with that and i know they found the fix for it.
May 30, 2009 | 1997 Acura TL Series
Computers & Internet Logo
161 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
