Question about Whirlpool GGW9200L Gas Dryer
Clothes warm but not drying
Burner ignites, runs appx 20 sec, shuts off & repeats this process appx every 8 min but does not stay on long enough to heat things up. Vents are all clean throughout and burner coils have been replaced per your suggestion
  • Mershie Apr 12, 2008
    Coils did not help at all. How do I get an error code to show up? Dryer has run without a problem at its current location for almost 2 years,
    President:
  • Whirlpool Master
  • 2,651 Answers
Did the coils help at all?? sounds as if its cycling to quickly, forom perhaps a bad cyclyng thermostat or a thermistor(usually would so an error code of e1--e2), you sure this is set for correct tyoe of gas,, lp/ natural???
Posted on Apr 12, 2008
Car keeps flooding an wouldn't start
Michael,
Flooding is a known problem with the RX-8 (unfortunately). It is designed to run at high RPMs for extended periods. Flooding typically happens if and when you initially start the car and turn it off before it has had a chance to warm up sufficiently. If it does flood, you can put a jumper cable on the battery (because this process will quickly drop your battery charge) and press the accelerator all the way to the floor (you should also remove the 20 amp fuse for the fuel pump). Turn the ignition for about 20-30 secs and then rest for 30 secs. Keep doing this (with accelerator fully depressed) until the car starts. It may take as many as 10 to 15 repetitions of this before it starts. If this does not work, then you will have to remove the left front wheel to access and remove the spark plugs (and repeat with the plugs removed).
Dec 10, 2013 | 2005 Mazda RX-8
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
Dryer runs, heats for 8 to 12 minutes, cycles off burner for approx 20 min. Then follows same process. Clothes are basically "air drying".
if it is a gas dryer check your vents there is an obstruction some where. to test this you can disconnect the vent from yhe dryer and tyr drying a load.
Dec 10, 2009 | Washing Machines
My gas dryer, LDG512, only burns gas for 8 secs, then shuts off for 90 secs then heats for 8 secs. Continuouscycle. I replaced High Temp thermostatic, checked vents - no obstruction. Taking +1 hr to dry...
Hi
First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find an open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work (get red), check it with an ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
If the igniter gets red and stays red, or you hear a click and it goes off, then a minute later its gets red again then possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then it’s the flame switch that is bad and maybe welded closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Maytag Dryers
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Whirlpool Dryer LGQ9508PW0 flame comes on and shuts off after 30 seconds.
this might actually be normal, whats the complaint??? to long to dry clothes maybe 2-3 cycles??? would be a common complaint. in which id check to make sure vent is not clogged anywhere, especially where exiting the home if he venting is ok id replace the coils atop the gas valve, possible and common for that matter that after running for 20-30 min they do not reopen and dont allow flem to reignite... part number 279834 retails for about $20 easy enough repair.... reason for flame to go on and turn off after only 30 secs is that in an empty dryer 30 secs of heat may be enough to satisfy the thermostat, that's alot of heat for an empty dryer, it would remain on for longer with a load of wet clothes absorbing the heat
Nov 05, 2008 | Whirlpool LGQ9858P Gas Dryer
Not drying
common cause for dryer taking to long to dry, (vent related issue) so long as thats be rectified, the next issue would be to look into replacing the coils atop the burner vale, part number 279834, retail for about $20, easy enough to change. although they appear to open the gas valve initially, after running for 30 min or so they overheat and no longer open the valve, extending dry time.
Oct 27, 2008 | Dryers
Whirlpool GGW9200L Gas Dryer Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
