Question about Fisher and Paykel Fisher & Paykel Washer
  • 144 Answers
I can explain how to check and repair this in Live chat. cheers
Posted on Mar 27, 2009
Code p1489 and p1490?????
is this a question or show and tell, minus the tell. ? LOL
did you google that first or read the FSM book first? seems not.
no engine option stated so, all answers may be wrong, 66% wrong.
like a 3 side'd coin toss.
ok ill type for you.
wow 20 thousand hits. WJ jeep it is.
or free fsm here, under emission chapter
Jan 13, 2011 | 2004 Jeep Grand Cherokee
I am writing about a vornado TouchStone Vortex 500 Heater. I plugged in another heat in another room and the lights went out. I reset the circuit breaker but the Vornado will not turn on. Cathy Giuli...
Call 1-800-234-0604 - This is Vornado's consumer service line. This manufacturer is well known for great customer service, and they should be able to tell you if something is wrong with the unit. If so, and if the heater is under warranty, they will fix it or replace it for free. You won't even have to pay shipping to send the unit in.
Oct 22, 2010 | Vornado TouchStone Vortex Heat 500 Heater
Model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
Mar 16, 2010 | Carrier 38CKC036 Air Conditioner
My refrigdarator keeps leaking water
Sounds like you had a dishonest service person come to your home. If the issue was water leaking and he replace a control board. The part he replace is very cheap about $56.00 and the reason to replace it would be if the refrigerator was not defrosting. I will return later with what to do. Sea Breeze
Nov 18, 2009 | Refrigerators
The thing thats wrong with it is that when you turn it on it clicks back off
This can be caused by by the sensor on the power board detecting an overload or short circuit in the sytem. Also insufficient ventilation can also set it to do this. Make sure the unit is away from the wall.
. Is the cooling fan heard when it turns on?
Samsung are one of the best companies to deal with. They have an online customer service number in phone listing for your country to call. They will usually replace their goods if its faulty. If it is under warranty or direct you to a repair facility.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 15, 2009 | Samsung LE40M91B 40 in. LCD TV
Disconnecting the power cable for the driver side mirror housing
it is under the defroster grid. you remove both A-pillar trim pieces first(they just pull off [plastic clips holding them]]) then the defroster grid(giant piece of plastic sweeping accross the dash) will also lift up[plastic clips holding it down] you cant miss it. very long pigtail to mirror will be in plain view above the speedometer.
Apr 07, 2009 | 2001 Chrysler Town & Country
Mk4 head unit not working
Hello There.
Thats an interesting one. My first suggestion would be to look at the DVD navigation unit in the trunk, does it have any sign of life, i.e will it eject the map dvd is there a blinking redlight etc, if there is nothing then thats most likely your problem if there life in it then I would suggest having a closer look at all the connections in the trunk. You need to remove the side cover in the trunk and check the connections.
If the above doesn't help, my guess would be your head unit has the fault.
The cheapest way to get this repaired is by process of elimination. If you think the DVD unit in the trunk is faulty I would buy one from ebay if you find this doesn't solve your problem you can always resell it on ebay without losing money and the same with your head unit.
Hope this helps. Good Luck.
If my answer has helped you, please rate me on Fixya.
Many Thanks.
Nov 12, 2008 | 2003 BMW 330
Further explaination to my roof problems.
replace softop control module assuming the repair facility did a good job. I would make sure you have power and ground to the unit. It is located in the r side storage compartment under plastic false floor. unplug unit for 30 seconds and reconnect and see if the unit begins to work. They do fail a lot.
Jul 13, 2008 | 1991 Mercedes-Benz Mercedes Benz Sl Class
Goodman CKL60-1L
Four things cause icing up:
( 1 ) Is your filter clean? dirty filter blocks air flow causing iceing up. replace filter
( 2 ) Do you hear the Indoor fan running? If the fans not running the unit ices up. Check Capacitor to fan if good.
Bad fan motor... replace fan motor and cap. If both good
( 3 ) Check Air Handler evap coil if dirty and or clogged, restricts air flow causing unit to ice up. Use toilet brush to clean.
This is always a big possibility if you have pets.
( 4 ) If the above are not present then you are low on refrigerant.
Low refrigerant will cause icing up because the gas does not flash properly. This will require a service tech.
refrigerant leaks can be as simple as a loose cap on the king valve, leaking schrader core, to coil leak.
Have the service tech show you the leak. If it is in a copper line it can be fixed. If the system is over 10 years old limit the amount you want to spend. 10 years is the standard life expectantcy anymore. Good luck
May 20, 2008 | Goodman CKL60AR60 Air Conditioner
Tv turns on for 1 sec then shute off power light blinks 3 times panasonic pt53wx53g projection
Hi 3 blinks on panasonic is the conversion ics. very common repair for projectors. you need to replace two ics on mother board. The cost of the repair from a tv shop is 250,00.
At least now you Dont have to pay a service center to come out and diagnose
Just give them your model number and they can look up the parts. The job take 1 hour to do or so.
I hope this help thanks doctor video leadingedgeelectronics 1987
May 04, 2008 | Televison & Video
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
