Question about Belkin (F5D7230-4) Router (587009)
Wireless G router hooked up correctly but not connecting to network adapters on computer. My software is Vista
  • Mark Kessler May 11, 2010
    Did you try detecting your wireless router then connecting to the router through your computer?
    Problem Solver:
  • 10 Answers
We're you able to see other wireless clients on your wireless network?
If you see an unsecured wireless connection, try to connect to it for the mean time just for testing purposes.If your router requires a network key, please enter it once you connect to your router's name. To verify, access the router's setup page and check the WEP/WPA setting.
Or call the toll-free Supportrix Tech Support at 1-877-787-8749 and give "support call" as promo code for one free technical support call.
Posted on May 05, 2008
My laptop runs Vista. It will connect to my network, but not to the internet. All of the other computers and devices connect to the internet with no problem. Can you help me?
If you are connecting to your router wirelessly try to check the wireless settings on your computer. It might be that you were not able to provide the correct security code for your wireless network.
If you are connected through an ethernet cable, check the connection from the router going to your computer.
Jun 01, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
We have two computers and we are trying to set up a network so both computers can use internet, the host computer has windows vista and coble modem the other computer has windows xp and is about 275'...
Hi.
You are going to need two things for this to work.
First, you need a wireless router, these usually run about $50-$60.
Then after you get the router, you need a wireless usb adapter, so that the xp computer can receive the signal from the router.
Connect the lan cable from the cable modem that is currently attached to the vista computer to the router, then connect a lan cable from the router to the vista computer.
The xp computer is easier.
After you have the router hooked up, just plug the usb adapter into the xp computer, install any software that comes with it, and after it install the drivers it will be able to connect to your router, and have wireless internet.
Make sure that you know the name of your router, that way you are connecting to the right one.
I hope this helps you out, and have a good day.
May 21, 2011 | Microsoft Windows XP Professional for PC
I have a HP Pavilion with Vista. I am trying to set up a new router (Lynksys E3000) but it will not connect. All my other computers work.
go into the start menu open network connections and the name of the network should show up if not than you may have too many devices connected to it at once/ no signal or the wire if you are using a wire is not hooked up correctly
this video shows you how to do everythinggood luck
have a nice day and post nice things
Mar 06, 2011 | Linksys (WIFIDESKTOP) Wireless Adapter
Dell 3300 adapter
Let me recap, just one more time.
Your wireless router,
You updated the firmware(most have out dated firmware from sitting in the warehouse)
Broadcast SSID
Using WPA-PSK(TKIP) Security
Mixed mode(b and g, n if available) This is needed for wireless devices to work properly.
Channels 1, 6 or 11. These channels are the channels most wireless devices work on the best(I use channel 11)
Now for the printer. Download and run this patch to completely remove the printer from your computer.
The patch is password protected. The way around the password protected zip file is to open the zip file with Winrar or 7zip(.exe file)
Restart your computer.
After router is done, now setup your wireless print server/printer.
3300 Utility
3300 Firmware
Attach the 3300 to your computer using the USB Cable and insert the 3300 disk. Follow the instructions. It should ask you for the network ID, type of security and password.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Install the drivers, choose network, choose I'm using a wireless print server(if you do not see this, then choose add printer and you should see it then) and follow the instructions.
Thanks for contacting Fixya
Jun 05, 2009 | Dell 3300 Print Server
Vista wireless networking with 2 computers cabled to router
To disable the ( redundant ) wireless connection, right click ' My network places' click properties, in the dialog right click your wireless connection, click disable. YMMV in Vista. There are several ways to disable an adapter, might try Windows Help.
If your "someone" installed Norton AV that's what degraded your performance. Remove it and pick one of the free ones like Avast or AVG. If the previous AV wasn't removed properly you're going to see a slowdown.
Dec 26, 2008 | Microsoft Windows Vista Home Premium with...
Wireless problem
Hello router_lost
I believe you are correct in your assessment that the issue is related to your router. Likely, that issue involves configuration - of your router and/or your laptop computer.
(01) Is the computer that is running Vista connecting to the Internet (via the router) using a wireless network adapter or a wired network adapter?
(02) Assuming that the Vista computer is connecting to the Internet wirelessly, please, tell us the manufacturer, model number and version of your router.
If the Vista computer is connecting "wired" and not "wirelessly" AND you have no other devices on your LAN (home network) that are successfully connecting to the Internet wirelessly through this router, then, it's possible that the router's radio is not enabled. However, if the laptop is "seeing" your router, then, of course, that isn't the case.
(03) Are you sure you are attempting to connect to the correct wireless router from your laptop?
I've seen it quite often where users will think they're connecting (or trying to connect) through their own router when, in fact, the router is a neighbor's (not their own).
(06) You can avoid this possibility by assigning an unique SSID to your wireless radio. In other words, change the SSID (wireless router's "name") to something other than the manufacturer's default SSID. (e.g. Netgear's default is "netgear" and Linksys's default SSID is "linksys", etc.)
It's best, for security purposes, not to assign a revealing SSID (e.g. "TheSmiths" or "2201YourStreetName", etc). Call it "BlueMoon" or whatever you like. Just something unique yet not revealing of your identity or location.
(07) Please, tell us the manufacturer, model number and revision of your router.
(08) Please, tell us the manufacturer, model number and serial number (or service tag) of your laptop computer.
(09) Please, tell us the operating system that is running on your laptop computer.
W/ this information, we'll be able to provide you with specific instructions for correcting your laptop's connectivity problem at home.
(10) Do you know if you have WEP or WPA encryption enabled on the router?
If you do, then you will need to enter either the router's wireless encryption "password phrase" or the hexadecimal key code password in order for the laptop to be allowed to access the Internet. You should only have to do this one time - then your computer will save the information.
If you've been connecting to free networks fine, then you've likely not been required to enter a password phrase or key in order to connect.
Please, post back here w/ answers to the questions I've asked here along with any other questions, comments, and observations you might have. We'll continue to work w/ you on this issue until it's resolved.
Thank you
BJ @:)
Apr 15, 2008 | Computers & Internet
Remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
Mar 14, 2008 | Computers & Internet
I can't get my new Vista computer to connect to my wireless network
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since.
If that doesn't help, try removing the Linksys software from your computer and try the network adapter remove/reinstall again.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Laptop connection to Internet
In the simplest terms buy a longer ethernet cable or multiple ethernet cables and route them to several preferred areas.
However believing you probably would like to connect wirelessly
If your laptop has a built-in network card and originally came with Vista you may need to configure the network adapter and/or the router appropriately. There are often user guides for the both the adapter and router that will assist.
If your laptop has an built-in wireless adapter and you upgraded to Vista you should check the manufacturers website using support or drivers links to see if they have Vista software/drivers to support your built-in wireless adapter. IF not you may want to consider the purchase of a compatible add-on wireless adapter as noted below. And perform the appropriate configuration(s) as noted above.
Likewise if your laptop does not have a wireless adapter you may wish to consider purchasing an adapter. Care must be taken that the adapter is compatible with your computer, your operating system (Vista) and your wireless router (apparently WBR-1310).
Dec 06, 2007 | D-Link 802.11g Wireless Router WBR-1310...
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Belkin (F5D7230-4) Router (587009) Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
