Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Lamp reset. I have a Zenith LCD Projection tv and replaced the bulb and tried to reset the lamp use time, however it still shows a total of 5176 hours. Model number M52W56 LCD. The picture is dark after changing the bulb. Thanks for any help.
    Problem Solver:
  • 17 Answers
There are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Posted on Aug 19, 2008
How do I switch the bulb in a DLP projection TV model RU-52SZ61D
I just replaced the bulb/lamp on my LG RU-52SZ51D TV. It was fairly simple. Basically you have 2 screws that hold on the cover panel on the right side of the TV. Once you take off the cover, you'll then see a metal tray with a handle. That has 3 screws, you can then pull out the tray and see the bulb/lamp. The lamp has 3 more screws that hold the little brackets that hold the lamp in place. Last you have the 2 power wires. One is connected by a screw on the left of the lamp, the other is attached by a nut and a washer on the back of the lamp, where you would usually screw in a normal light. The two wires are just connected to a single plug to the right of the lamp which you can remove, you get the new lamp with the wires already attached. All you have to do is plug it in after you mount it back up. Here is the info on purchasing a lamp, sorry but I am still in the process of learning how to reset the lamp indicator light...
Website:http://www.partstore.com/ProductDeta...ModelID=491016
Zenith Projection TV Lamp
Zenith Part Number: 6912B22002C
LG Electronics Model: RU52SZ51D
Don't miss your favorite programs, keep an extra Zenith TV lamp on hand. NOTE: THIS PART IS MANUFACTURED BY OSRAM. IF THE OLD LAMP WAS MADE BY OSRAM, USE THIS PART.
Price: $ 273.83
Here is how to reset the lamp timer.
lamp reset on lge :to reset lamp timer press and hold ENTER or OK on tv display and MUTE on remote at the same time for 5 to 10 seconds, lamp reset box will pop up you can then reset lamp.
Aug 27, 2011 | LG RU-52SZ51D 52" Rear Projection...
Lamp timer near 10K
just go through the manual it will guide you to solve your problem..........
Aug 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
I HAVE A 52" ZENITH
There are several models on several generations of Zenith manufactured LCD projection tv's. Without knowing the exact model of yours i can't be sure but in most of them the Lamp life counter is reseted this way: with the tv in stand-by, you press the "?" key on the remote then immediately you press 9,8,7,6 and then the OK. If the procedure was correct the 3 lights on the front of the tv will blink to signal the end of the reset procedure.
In others , hold down the Mute button on remote and Enter on TV at the same time for a few seconds, you should get a screen prompt asking if you want to reset the timer for the lamp.
May 25, 2011 | Televison & Video
I replaced my lamp bulb and everything works fine. The only problem is that the orange, replace indicator, is still on. Is there a way to reset it or something? TV and everything works great just the...
Try tv unplug,replug it back like an hour later.The tv will reset itself,back to the factory setting.It should detect the projection Lamp life are good and a new Lamp.The "LAMP" LED Light indicator,will go off.
Nov 30, 2010 | Zenith E44W46LCD 44" Rear Projection...
I replaced a lamp on a Zenith Projection LCD TV model # D52wlcd. The new bulb is working fine. However, the end of bulb life indicator light ( orange ) would not go off. Any advise on how to reset the...
Resetting the lamp time
After pressing the "?" key on the remote control in Stand-By mode, press the "9876"
and press the "OK" button.
And then three LED in the front is stop after flashing for a moment.* Lamp Life Time Confirmation
1. Method1 : Enter ADJ mode with using the remote control. You can be confirmed
because " Lamp Life Time XX hr" is appeared.
2. Method2 : With using the remote control offered to consumer if you press the
menu button continuously, OSD menus will disappear then press the "9876" and
press the "OK" button to enter ADJ mode you can see "Lamp Life Time XX hr"
Oct 13, 2010 | Televison & Video
Replacing lamp
try this to see if it works!
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the
counter…Otherwise you may get an annoying reminder every few days if you’re
surpassed the predetermined hour mark.
Ensure the TV is powered on.
Press and hold the MENU button on the TV
Press and hold the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
Let go of the REMOTE button first, then release the button on the TV
Press and hold the ENTER (or OK) button on the TV
Press and hold the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly… offer your inputs!
Apr 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
Lamp reset
The correct way to reset the lamp timer on that unit is to hold the menu key on the remote and push the enter key on the front of the TV at the same time. Hold them (it's about 9 or 10 seconds) and then a screen comes up asking if you would like to reset the lamp timer. That will reset the time but if your problem is a dark picture that's probably not going to fix that.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
357 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
