posted by colea22 on Apr 12, 2008
When I turn on the projector it boots fine and goes to a blank white screen. I cannot get my computer to connect and when i press menu on the top of the projector or on the remote nothing happens.
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 18, 2008
Same thing...
Comment by nheagle, posted on May 10, 2008
Help!
Best Solution
posted on Jul 19, 2008
open the projector (6 inset screws on bottom) - carefully rermove the top (there are 2 wire sets attached: one for the speaker and one for the control panel) -- make sure all wire sets are properly seated -- i had one loose set -- reseated it, closed the projector and the thing wotks fine now. every repair facility i called didn't want to deal with the projector, and one person told me i ought to buy a new one
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 28, 2008
vubm is exactly right. I opened it up, saw that the largest wireset was loose, tightened it up and it worked just fine. Thank you vubm. Sometimes hearing that someone easily opened it up and saw an obvious problem is all it takes to make it happen.
One small addition to his post: one of the small black screws on the back was also holding on the top. It was the top black one in the remote control compartment on the back. I got frustrated and just broke my off, but when I did, I saw that it was just that small black screw coming in from the back.
Suggest a new solution for this problem
Post a New problem for Epson EMP S1 Multimedia Projector
Email this problem
Email this problem
Can you Help with these Multimedia Projectors problems?
ge vivid i does not start...
begun re-starting several times... Answer This...
(old) InFocus LP335 Projector -...
I recently had my boss walk... Answer This...
flashing red light
flashing red light
when i plug the power cord in... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
